March
29 30 31
DIVEBUDZ, OlafKnute, Brooks Ritchey, vcyachting, Badfish2
932 Registered Users
868,933 Dacron Main
133,427 Ananda's Refit
Topics3,776
Posts18,430
Members932
Most Online223
Dec 17th, 2019
Page 3 of 7 1 2 3 4 5 6 7
Re: Ananda's Refit [Re: Rob Van Name] #15976
11/29/14 12:26 AM
11/29/14 12:26 AM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
Originally Posted by Rob Van Name
Alex,
How did these port lights tolerate the curve of deck house? Did you have to build up so they lie flat?
Rob
Now that I've installed them, I can tell you that they tolerate the curve just fine. It takes a bit of effort to close them, but they seal perfectly.
Re: Ananda's Refit [Re: alx] #15985
12/15/14 09:43 PM
12/15/14 09:43 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
I wired the head and it works beautifully. The only catch is that I ran 16 gauge to the unit, and after I installed it I read the instructions (that's the arrogance of a nerd there, installing something before reading the manual) and it specifies 8 or 6 gauge should be used. There's no way I'm running that thick a wire to and from my panel, and that doesn't make sense when the panel's wired with 12 gauge anyway. Instead, I'm going to run 6 gauge from the battery directly, controlled by a solenoid which is actuated by the switch on my panel.
One problem I had to solve was that the new panel does not have built in fuses (I did this on purpose) and is significantly larger than the old. At the same time, I'm adding more electronics (AIS receiver, thermostat, refrigerator control, etc) that needs somewhere to live. To address this, I decided to hide all the electronics in one of the J/30's four main cabin cupboards, behind sliding plastic doors. So my dad built a backing wall within the space, and I mounted the electronics on one side and the fuse boxes on the other, with all loads terminated at the fuses. It's starting to look pretty nice:
Re: Ananda's Refit [Re: alx] #15986
12/15/14 09:44 PM
12/15/14 09:44 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
This weekend was a very productive one for me!
On Saturday I ran ducting for the Espar under the main cabin seating on the port side. The duct exits the cockpit locker, snakes down under the galley shelf, and passes through the wall under the galley sink. From there it dives down a few feet and passes through another wall into the space under the seating there. It connects to a Y fitting where the main flow passes through to the vent, and a smaller offshoot will carry air forward into the head and v-berth compartments.
My hole saw was a little too small for the 90mm ducting, so this is how I drilled out bigger holes:
Duct passing into the compartment under the galley sink:
The run under the sink. This is a very useful space - it also contains the battery charger, audio amplifier, and freshwater demand pump and filter. I've since resected a lot of the wiring and it looks a lot cleaner than this:
Sunday I turned my attention back to electrical, and passed an important project milestone.
The old wiring system used a hot wire for every circuit and then a shared common ground. All the wires were bundled together and ran in a loop around the boat - from the panel on starboard aft back to the transom, across the transom and forward along the port side all the way to the v-berth. I wanted independent common and hot wires for each circuit, which makes it much easier to replace wires, add new circuits, etc. I also wanted to avoid the long loop back to the transom, which meant passing several of the wires through the engine compartment. This was a pain, as every time I wanted to run one of these wires I would have to remove the engine cowling.
Yesterday I ran the last of these circuits (chartplotter, instruments, audio, and amplifier on switch). It was a great moment because it meant I could finally bundle up the loose wires I had snaking around the engine and tie them down properly.
First I wrapped them up nice and tight with electrical tape:
Then covered them in corrugated conduit (slightly too large for the bundle, but used for chafe protection against the mounts):
They're tied down with three wire ties to ensure they don't go anywhere. I'm so happy to get this part of the project done - I only have a few more circuits to run at the panel. The biggest part of the remaining wiring are all the navigation lights. Those run to a waterproof switch panel to be installed in the cockpit, so all navigation lighting can be controlled independently without having to leave the cockpit and find the right switch to set in the dark cabin.
Re: Ananda's Refit [Re: alx] #16052
01/21/15 12:36 PM
01/21/15 12:36 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
Hey all! Work has been slow since the girlfriend's been in town for a month or so, but still things are coming along.
Previously in the boat, those were controlled at the panel in the cabin, which is not ideal when switching between power and sail at night. I really wanted to have control over the nav lighting from the boat's exterior, so I mounted a waterproof switch panel next to the engine controls:
I've removed the traveler track and end control hardware. Under a turning block on the port side I found the worst water intrusion into the deck core that I've seen yet. The balsa here was so saturated that compressing it while digging it out caused it to dump water like a sponge. Yuck! I drilled a pattern of holes to follow the rot and excavate the saturated material. They'll be filled with epoxy before the KiwiGrip coat goes over top:
Location of the old turning block which caused the whole mess. You can still see some of the caulking - this was causing significant amounts of water to drip into the quarterberth below, and the previous owner just covered the tops of the bolts in caulking instead of fixing the problem for real:
The rest of the traveler track was in much better shape, and the starboard side had only minimal water intrusion in the same location:
My new traveler setup is going to be much bulkier. Here's the new car next to the old. It clearly doesn't fit in the groove, of course. The groove will be filled with a length of teak and the new track mounted on top. It will extend further outboard, almost to the edge of the cockpit. I'm doing this to recover length lost due to the larger car and end controls:
[Linked Image].
Here is the electronics hub currently, with about 80% of circuits wired:
I thought I would take some pictures of my Espar setup for you all since I don't think I've shown any before. The heater is mounted on a beam that spans between the transom and an aft bulkhead. Exhaust exits in the sleeved tube and loops in front of the unit, passing overhead to meet the transom fitting at a downward angle:
Transom fitting is sealed with high-temperature gasket sealant and is a good 2' above the waterline at neutral heel.
The fuel pump is mounted on the bulkhead at an upwards angle per the instructions:
I've also hired Gianola Canvas out of Sausalito to make all-new interior cushions. They're going to be done in a material called Ultraleather, which will be a significant improvement from the burlap sack interior I have now.
In other good news, my dad arrives next week for phase 2 of the renovation! Our list is much shorter this time (with a few new items):
  • Finish up miscellaneous plumbing, wiring, and mounting tasks.
  • Engine oil change and routine checkup.
  • Re-bed all stanchion bases to ensure watertight seals. No leaks on the new cushions.
  • KiwiGrip!
  • Potentially mounting a radar unit on a self-leveling pole off the transom.
  • Potentially mounting a retractable bowsprit on the foredeck.
  • Going sailing!
  • Going sailing some more!
Re: Ananda's Refit [Re: alx] #16057
01/21/15 10:33 PM
01/21/15 10:33 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
ALX,
I mounted Raymarine radar on a 10' Edson mast just forward of the transom on port side. The mast requires two bracing rods.
The Edson mast runs through the deck and the mast base is supported on a built up teak wedge.
Could you tell me roughly what it cost to do up your cushions?
Rob
Re: Ananda's Refit [Re: alx] #16058
01/22/15 01:12 PM
01/22/15 01:12 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
Hi Rob,
I'm looking at a Scanstrut 8' mast with a self-leveling mount. It through-bolts to the deck and has two support struts, one mounted on the deck and the other on the pushpit.
The cushions came in around $4,500. It wasn't the cheapest of the options I considered, but going with a local company meant they could visit the boat and pattern everything directly. I also had the option to re-use my existing foam (which would have lowered the price) but mine is too far gone to be salvageable.
Re: Ananda's Refit [Re: alx] #16059
01/22/15 03:05 PM
01/22/15 03:05 PM
St. Helens, OR USA
Koesh Offline
Koesh  Offline
St. Helens, OR USA
Awesome Job!
Looks like you've added a lot of wattage consumption. What have you done for batteries? I need to add some improved "house" battery storage and I'm looking at ideas.
:Doug
Doug Marshall
Koeshtkah #207
Re: Ananda's Refit [Re: alx] #16061
01/26/15 12:27 PM
01/26/15 12:27 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
Hey Doug, sorry for the late reply.
Batteries are actually an unsolved problem for me. Currently the boat has two identical dual purpose FLA batteries that are physically on the small side (car battery form factor, 2 of them fit into the battery box), but labeled as 140 Ah each. Based on testing and common sense, this seems ridiculous. In my research I haven't been able to find anything close to that capacity in such a compact form factor. The current ones do need replacing though - even after full charging cycles they're putting out 12.06 V each :-/
I'm looking at doing a split house/engine battery, with a 200+ Ah deep cycle for the house and a separate starting battery. I have an ACR for combined charging when running the engine and isolation during normal operation. I also installed individual battery switches so I can run the entire boat off of either battery individually if needed.
Re: Ananda's Refit [Re: alx] #16064
02/02/15 12:31 PM
02/02/15 12:31 PM
San Francisco
alx Offline OP
alx  Offline OP
San Francisco
With Team Dad & Son reunited, the (hopefully) final sprint to the finish has officially begun.
On Saturday we met early with the A-sprit inventor who promptly measured the bow and drilled the mounting holes for the sprit. It felt kind of like piercing the boat's nose. As the piercings passed through the cored part of the hull, we dug out the core and added a seal of MarineTex to keep water from ever making it to the core. The core came out completely dry, thankfully - no water intrusion issues in the hull itself.
A fiberglass ferrule fits through the holes, and a smaller tube slides into it to form a hinge. The sprit frame then bolts to the inner tube. We should have the whole thing assembled and rigged in a few days and I'll post some more pictures as this part of the project progresses.
Mounting the new battery charger was the next project. Actually - I don't think I told you guys about that. My shiny new Blue Seas P12 battery charger failed after a couple weeks of operation. I got on the phone with the customer support department who walked me through checking a few of the more common failure modes before agreeing that the unit was defective and shipping me a new one. So I switched all my wiring over to it and got it mounted, and it's working flawlessly.
Next we removed the temporary board from the missing 4th window and bolted the new one in place. It feels really good to have all four windows in:
Excess MarineTex went to fairing some of the deck holes in preparation for Kiwigrip operations, which begin next weekend. To that end, I also mixed up a batch of thickened epoxy to replace the rotten core on the port side of the traveler:
I'm very much looking forward to the Kiwigrip - the deck will look so nice afterwards! I'm planning on having my GoPro on and filming the gripping operations for a timelapse.
We pulled the starboard stanchion bases out in preparation for re-bedding, as well as some nearby pad-eyes. The backing plates were in mostly horrible condition - thin acrylic plates that were warped or in some cases completely cracked.
As night fell we headed inside and worked on mounting the Raritan electric toilet controls. I used a teak light switch plate from West Marine to avoid drilling a large hole in the formica around my head sink, and we caulked behind it as a precaution in case splashing in the sink causes water to drip down over the plate. I think it looks pretty good:
I've got some work to do to tidy up the toilet electronics before crossing that project completely off my list.
Sunday morning we crossed the Golden Gate as the sun came up and landed in the West Marine parking lot by 9am. After a quick run to the hardware store and across the Richmond bridge to another West Marine (needed two pad eyes and each store only had one) we finished our tour of bridges by crossing the Bay Bridge back into San Francisco and got to work by noon.
Most of the work Sunday was spent re-bedding the stanchion bases, including manufacturing new backing plates from 1/4" G10. The new plates are at least thrice as sturdy as the old ones. Plate cutting operations:
And the result:
This is one stanchion that's not going anywhere:
Placing the base with sealant applied:
And here's my dad being a master of detail work with the sealant:
One base in particular was most painful, as it was mounted behind the electrical box we built into a cabin cupboard. To access it, I had to remove one Raymarine box and pull the board out just enough to reach behind. My arm is red with scratches and cuts from wedging it between the boards to tighten nuts, but all the bases are firmly in place. The port side only has three bases to re-bed, thanks to the lack of a lifeline gate.
This week Dad is focusing on sanding and fairing the deck in preparation for Kiwigrip. I'm going to be working on getting the new traveler mounted and rigged. Hopefully by Saturday we'll be taping the deck and mixing us some non-skid!
Re: Ananda's Refit Sprit Install [Re: alx] #16065
02/03/15 01:00 PM
02/03/15 01:00 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
if at some time you can separate out the sprit story ... with its own subject line [so it will pop in a google search] ... there are a lot of people out there that would be interested in how you did it. and eventually how it runs.
v
0 registered members (), 36 guests, and 1 spider.
First cruise
Freeze question
by --Ajax--. 03/01/21 09:32 AM
J-30 sails and parts
by Bob Rutsch. 02/24/21 04:54 PM
What's Inside the Boom
by --Ajax--. 02/24/21 08:22 AM
Looking for J30 main
by the redhead. 02/23/21 01:48 AM
#1 and #2 jib
by the redhead. 02/23/21 01:36 AM
Origo alcohol stove 4100
by the redhead. 02/23/21 01:33 AM
In Need Of J-30 Spinnaker
by j30sailor. 02/20/21 02:20 PM
by Koesh. 02/13/21 01:59 PM
Sails: Main, Unknown, #2, #3, Spinnaker in CA
by watchoverya. 02/13/21 01:52 PM
Deck core
by Phil Spletter. 02/11/21 10:00 PM
