March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,359 Dacron Main
162,678 Ananda's Refit
Boom Section #16074
02/07/15 06:16 PM
02/07/15 06:16 PM
Milwaukee, WI
Hullabaloo Offline OP
Milwaukee, WI
I"m looking for about a 2' section of boom. If anyone has a broken boom they're willing to cut a piece off of, let me know.
Tom Heinrich
Hullabaloo #443
Hullabaloo - J/30 Hull #443
Re: Boom Section [Re: Hullabaloo] #16081
02/12/15 01:19 PM
02/12/15 01:19 PM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
Hi Tom,
I have a whole Boom. Are you looking to sleeve one?
I am north of Detroit. Shipping is a problem for a whole boom. I am very reluctant to cut it.
Re: Boom Section [Re: Hullabaloo] #16082
02/13/15 09:51 AM
02/13/15 09:51 AM
Milwaukee, WI
Milwaukee, WI
Hi Don,
Yes, looking to sleeve it at the Vang connection. I'd rather not have you cut up a good boom. I'll find another alternative.
Thanks!
Tom Heinrich
Hullabaloo #443
Re: Boom Section [Re: Hullabaloo] #16083
02/13/15 10:47 AM
02/13/15 10:47 AM
Tom,
Check this old post for a possible solution.
Re: Boom Section [Re: Hullabaloo] #16084
02/13/15 06:31 PM
02/13/15 06:31 PM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
Tom. The Rig Rite sleeve is a very good solution. I am very confident in my sleeved boom. It took some work to get to fit right. Then the Lancote applied and riveted in. Now I vang sheet all day without worry.
That's why I bought the spare boom and never used it. I sleeved my original instead. Good Luck
Re: Boom Section [Re: Hullabaloo] #16135
03/08/15 08:26 PM
03/08/15 08:26 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
I'm considering reinforcing my boom with a 12" long piece of 2" aluminum angle iron. The thought is to drill holes for 1/4" or 5/16" bolts through the apex of the angle iron about 8" apart. Drill matching holes in the boom that straddle the vang. Put the bolts into the angle iron and with the legs facing down, slide the angle iron into the boom until the bolts come thru the boom. With the bolts tightened I would essentially have a triangular box inside the boom supporting the vang. Seems this would be stronger than a sleeve? Any thoughts on why this is a bad idea?
Re: Boom Section [Re: Hullabaloo] #16136
03/08/15 10:08 PM
03/08/15 10:08 PM
Key West, & Charlotte, NC
lumpy Offline
lumpy  Offline
If you or anyone is interested in a boom.
Ted Kaperonis,, tkaper6862@aol.com, still has a boom that is for sale. I saw it last week and is looks to be good condition. It is a fully rigged white boom. I did not see any corrosion, dings, or forehead impressions.
Lumpy
Scott Davis
Night Nurse #363
Re: Boom Section [Re: Hullabaloo] #16137
03/09/15 07:55 AM
03/09/15 07:55 AM
Rockwood, MI, USA
Rockwood, MI, USA
My boom is new in 2007. Just looking to reinforce it at the load point of the vang
Re: Boom Section [Re: Hullabaloo] #16231
04/30/15 04:47 PM
04/30/15 04:47 PM
CHICAGO
JKC Offline
JKC  Offline
CHICAGO
Are you still looking for piece of boom? I have broken one sitting in garage. I could cut a piece and send. I did this vang reinforce project a few years ago.
0 registered members (), 35 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
