March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,298 Dacron Main
162,662 Ananda's Refit
Replacing fuel tank #16202
04/13/15 12:34 PM
04/13/15 12:34 PM
Highland Park, NJ
Steve Buzbee Offline OP
Highland Park, NJ
Mine is leaking and I have purchased a replacement. Does anyone have any tips on removing the old tank and installing the new?
Blue Meanie J/30 #485
Re: Replacing fuel tank [Re: Steve Buzbee] #16204
04/13/15 08:00 PM
04/13/15 08:00 PM
Portland, ME
JBiermann Offline
JBiermann  Offline
Portland, ME
That is a head scratcher Steve, I will take a peek at mine tomorrow. Is your replacement the same shape and size?
Re: Replacing fuel tank [Re: Steve Buzbee] #16205
04/14/15 02:41 PM
04/14/15 02:41 PM
Highland Park, NJ
Highland Park, NJ
Yup!
Re: Replacing fuel tank [Re: Steve Buzbee] #16206
04/14/15 03:09 PM
04/14/15 03:09 PM
Cape Elizabeth, ME
Kinesis497 Offline
Kinesis497  Offline
Cape Elizabeth, ME
Steve, I removed mine to clean it and had to cut away the fiberglass tabs holding it in place. With a bit of effort the tank then slid aft and out the storage cutout. I left the vertical section of the tabs in order to thru-bolt some new L-shaped plywood tabs that now hold the tank in it's place. Sam
Re: Replacing fuel tank [Re: Steve Buzbee] #16210
04/15/15 12:39 PM
04/15/15 12:39 PM
Highland Park, NJ
Highland Park, NJ
That is kind of what I thought would be the way to do it. Thanks!
Re: Replacing fuel tank [Re: Steve Buzbee] #18060
11/11/18 10:32 AM
11/11/18 10:32 AM
MD
U
usa1136 Offline
usa1136  Offline
U
MD
Steve, any suggestion for this project, since you went through it already. What mfg did you go with for the new tank? I Stopped up the drain holes from the engine and diesel compartment with oilsorb sheets to try to confirm the source is the tank.
I‮m starting to see diesel in the bilge and it doesn‮t look to be coming from the engine. I‮m assuming, for OD rules, we can‮t install a plastic or smaller tank?
Re: Replacing fuel tank [Re: Steve Buzbee] #18065
11/15/18 06:50 PM
11/15/18 06:50 PM
Highland Park, NJ
Highland Park, NJ
I actually found a used tank that was off a boat being "parted out". Pretty sure you have to stick w metal tank for OD, but you might want to ask LC. I did locate a fabricator who could make a new tank as I recall-I will see if I can find the info about it.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
