977,783 Dacron Main
163,165 Ananda's Refit
Headstay Tension #16245
05/07/15 11:02 PM
05/07/15 11:02 PM
Portland, ME
JBiermann Offline OP
Portland, ME
Last season was my first in the racing division in our local wednesday night PHRF fleet. A more savvy and determined crowd than the cruisers I was used to by far. Needless to say, our first season with the spinnaker would not read like a hopeful underdog-cinderella story found in so many b grade movies. We had a pretty rough year.
Obviously hoping for a little bit more edge this season, I'm paying particular attention to tuning the rig. Measuring my forestay, I noticed is was considerably short of the 35' 10 1/2" max yet even with my buckles backed almost all the way off I continue to be slightly short (about 35' 8"). What's more, my forestay is feeling feeling considerably looser, even with my rear shackles tightened all the way in. Not floppy exactly... but definitely looser.
Is my fore stay supposed to feel a little loose? Will being a little short of 35' 10 1/2" make a huge difference? Anybody have the secret to becoming a drastically better beer can racer? Shrouds are at 1050 outer and 950 inner.
Re: Headstay Tension [Re: JBiermann] #16246
05/07/15 11:39 PM
05/07/15 11:39 PM
Rhapsody #348 Online content
Rhapsody #348  Online Content
Josh,
Make sure the forward edge of the mast base is positioned 1" back from the molded lip at the base of the mast. This needs to be set correctly. It sounds as if the mast base is too far back (make the mast top too far forward). Also make sure the mast is centered and blocked at deck so the dimensions are 3505 + 13mm = 11'6" + 0.5" stemhead tip to mast front edge ( Rules paragraph 5.7.3).
By centering the mast, it means a straight line from bottom of keel, through center of boat, to top of mast - all in line. This can be done on the hard with a plumb bob sighting about 60 feet behind the boat, or a laser level. Note that the mast may not be centered in the partners when this is done.
Re: Headstay Tension [Re: Rhapsody #348] #16247
05/08/15 07:41 AM
05/08/15 07:41 AM
Portland, ME
Portland, ME
Thanks Bill, I will double check those measurements though I believe that it should be set correctly (with the gap ahead of the front of the mast and centered). I should have been more clear, both the headstay AND the back stay (untensioned) feel loose compared to where I had them set last year. Headstay turnbuckle is backed way off and backstay buckles all the way in.
I dont know if you can tell anything just by looking but I will attach a photo with the rig in it's current configuration.
onthemooring.JPG [118.85 KBytes] - (748 downloads)
Re: Headstay Tension [Re: JBiermann] #16248
05/08/15 11:14 AM
05/08/15 11:14 AM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
With the adjustments to forestay and step position, you'll probably be needing more upper tension than last year.
Once you have enough upper tension, you may find your backstay quite floppy, even with the backstay turnbuckles maxed. The standard backstay was usually cut too long for this sort of tuning. You'd probably have to put quite a bit of backstay on before it does anything at all really. And you'll also not have much adjustment. What you might have to do is cut the backstay shorter. It's a little bit less expensive to have the top cut, rather than the 2 legs.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: Headstay Tension [Re: JBiermann] #16249
05/08/15 11:16 AM
05/08/15 11:16 AM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
In case you missed it, there is a wealth of advice in the various tuning guides on the main J/30 page.
Backstay doesn't really factor into rig tune. It should be loose enough to wobble sailing upwind under 10 knots. A quick flick should be all it takes to clear the backstay from the mainsail top batten during a gybe. Adjust turnbuckles so that the bridle blocks, when loose, return to connector plate at the top of the split. Tension using the purchase as breeze increases and the boat becomes over-powered to flatten the main. In a blow, tighten the turnbuckles so the backstay purchase is more powerful. To set shroud tension start with the lowers, then tighten uppers, sighting up the mainsail luff groove in the mast to keep the mast in column.
There should be some play in the headstay once the shrouds are set. It won't be bone tight. It can be difficult to get an accurate measure of headstay length with the rig up. The method described in this post works well enough for me. You can attach a dumbbell or jug of water to the halyard to maintain consistent tension as you measure. There are two schools of thought on headstay with some always at max and others, myself included, going tighter as the breeze increases. Looks like you have roller furling, which probably means set it and forget it, but 35' 8" is very tight. Could you add a toggle to extend the headstay?
Re: Headstay Tension [Re: JBiermann] #16250
05/08/15 03:09 PM
05/08/15 03:09 PM
Highland Park, NJ
Steve Buzbee Offline
Highland Park, NJ
Along with all the good information above-you shouldn't just set shroud tension to base and leave it. We re-tune between every race (unless conditions are exceptionally stable)more or less following the North tuning guide you can find elsewhere on this website. And to re-emphasize what was said above-the position of your mast step and partners is critically important in order to have all the other rig tune information work properly. Bear in mind that just 1/2" of fore/aft adjustment at the mast step will move the rig forward/aft over 4" at the forestay attachment point. This will make a huge difference in all your settings. You want to set the loose rig up with the maximum rake permitted by class rules-the boat is power hungry with very light helm feel in lighter air-getting the rig back will help point, and give you a much better feel on the helm.
Blue Meanie J/30 #485
Re: Headstay Tension [Re: JBiermann] #16251
05/08/15 06:58 PM
05/08/15 06:58 PM
Portland, ME
Portland, ME
Thanks guys, I appreciate all the input. I will double check that I have the correct spacing between the front of the mast and the "lip". I have the sail tuning guide as my sherpa though this process, that is what prompted me to measure my forestay.
My rig currently is not what I would consider "floppy", There is no sag in the forestay and the backstay block pops up pretty close to the "y" when it is loose. It is just looser than how I had it set last year, maybe I just needed to hear that this is alright.
I will look into having my back stays cut so that I have more tuning room but the mast looks, to my eye, raked much farther back than last year. If I can get the back stays shortened I will add a buckle to the forestay to get that extra 2 1/2". For now, even if I'm a little loose, I guess I can just play my backstay hard if the breeze comes up.
Re: Headstay Tension [Re: JBiermann] #16260
05/11/15 12:03 PM
05/11/15 12:03 PM
Highland Park, NJ
Highland Park, NJ
Remember that the backstay will not affect the rake of the mast-only how much bend there is in the rig. The rake is predetermined by the position of the step and the partners.
Re: Headstay Tension [Re: JBiermann] #16532
10/26/15 02:49 AM
10/26/15 02:49 AM
St. Helens, OR USA
Koesh Offline
Koesh  Offline
St. Helens, OR USA
How does your helm feel with the current set-up compared to last year? In 10-12 knots I like to be able to feel just the start of some weather helm with the boat fairly flat. That tells me where my mast rake is as much as tensions. I keep the headstay at max length (35'-10.5") and tension the rig according to the wind conditions. 'Course, right now it's all sitting on the trailer while I do core repairs, but that's the intention once she's back in the water smile
Doug Marshall
Koeshtkah #207
Re: Headstay Tension [Re: JBiermann] #16534
10/26/15 03:12 PM
10/26/15 03:12 PM
Honolulu, Hawaii
Erik Offline
Erik  Offline
Honolulu, Hawaii
Sorry to hijack this thread, but what about for those of us racing PHRF only, without the possibility of one-design racing. What is the optimal position for the mast step? Is the one inch aft rule because that's what the one-design rules permit or is it because that is the optimal position?
Erik
Honolulu
'Mango Madness'
#185
0 registered members (), 42 guests, and 8 spiders.
