March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,359 Dacron Main
162,678 Ananda's Refit
Re: Gates installed on J 30s [Re: Charlie Hurd] #16388
07/17/15 08:05 AM
07/17/15 08:05 AM
Maine
J
Jangles13 Offline
Jangles13  Offline
J
Maine
Starboard gate #419
Re: Gates installed on J 30s [Re: Jangles13] #16389
07/17/15 04:42 PM
07/17/15 04:42 PM
Kailua Kona, HI
last fling IV Offline
Kailua Kona, HI
#228- Starboard gate, added lower gate
Re: Gates installed on J 30s [Re: last fling IV] #16390
07/18/15 08:48 AM
07/18/15 08:48 AM
Richmod, VA
Phil Offline
Phil  Offline
Richmod, VA
Hull #25 - No Gate
Re: Gates installed on J 30s [Re: Charlie Hurd] #16395
07/21/15 02:50 AM
07/21/15 02:50 AM
Squamish, British Columbia
NaturalHigh Offline
NaturalHigh  Offline
Hull 95, no gates
Re: Gates installed on J 30s [Re: Charlie Hurd] #16413
08/03/15 01:05 AM
08/03/15 01:05 AM
Vancouver, BC, Canada
dlabrosse Offline
dlabrosse  Offline
I have gates on the starboard side of my lifelines. Not sure if they were standard or installed later. Hull number #92 1979.
Dominique Labrosse
Red Five, #92
Re: Gates installed on J 30s [Re: Charlie Hurd] #16431
08/12/15 02:19 PM
08/12/15 02:19 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
Starboard gate was standard in 1981 ... had on #327. then same, same #505 and #526. Starboard is where the launch pulls up as most launches have controls and operator on port side. ... so ok you slip guys don't understand that kind of stuff.
Re: Gates installed on J 30s [Re: Charlie Hurd] #16432
08/12/15 02:21 PM
08/12/15 02:21 PM
Oswego, NY USA
Crusader586 Offline
J/30 BOG Member
Crusader586  Offline
J/30 BOG Member
Oswego, NY USA
# 530 has Starboard Gate
Re: Gates installed on J 30s [Re: Charlie Hurd] #16496
09/26/15 07:24 AM
09/26/15 07:24 AM
Bermuda
Sean Offline
Sean  Offline
Bermuda
#319 has a starboard gate (Upper, not lower) will be adding in a lower this season however.
Re: Gates installed on J 30s [Re: Charlie Hurd] #16498
09/27/15 07:12 AM
09/27/15 07:12 AM
New Orleans
Grimm Offline
Grimm  Offline
New Orleans
Hot Chocolate (hull # 360) has port and starboard gates. We find this very convenient when tying up transient docks. I got lucky, one of the previous owners had them installed. However we are about due to replace the lifelines, and the two gates do make the task a little more complicated.
0 registered members (), 35 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
