Re: Swim Ladders
[Re: Sean]
#16954
08/29/16 03:08 PM
08/29/16 03:08 PM
Posts: 36 Bermuda
Sean
Bermuda
Ok, with all of the other projects on the go, sanding and painting the topside, a recore on a soft spot fore of the mainsheet track and general maintenance, I still haven't mounted my ladder on the stern.
Has anyone else done a stern mounted ladder setup? Did they bolster the transom with a mounting plate on the inside, or just screws and large washers? If a mounting plate, what was used?
My ladder provides for 6 mounting screws through the transom, three on each side.
Thanks.
Re: Swim Ladders
[Re: Sean]
#16962
08/29/16 08:52 PM
08/29/16 08:52 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
On Rhapsody when I recored the transom I glassed in a solid area that the ladder mounting screws went through. See this link on my recore blog. At a minimum you should over drill and epoxy isolate the mounting screw holes. I would use stainless shoulder washers on the inside under the hex nuts.
45
guests, and 0
