January
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
cstoddard
Kenpickard, Danproawesome, Don N, George Leese, ShaneKilberg
926 Registered Users
861,380 Dacron Main
131,814 Ananda's Refit
Topics3,768
Posts18,394
Members927
Most Online223
Dec 17th, 2019
Rudder #15308
11/04/13 03:27 PM
11/04/13 03:27 PM
Highland Park, NJ
Steve Buzbee Offline OP
Highland Park, NJ
Does anybody out there have access to/own a set of templates for the rudder? I'd like to fair mine to templates this off season. It is currently pretty assymmetrical. Related question-what does the new class certified rudder cost to buy?
Blue Meanie J/30 #485
Re: Rudder [Re: Steve Buzbee] #15309
11/04/13 03:37 PM
11/04/13 03:37 PM
Rhapsody #348 Online content
Rhapsody #348  Online Content
Steve,
You can create a template pretty easily using the excel spreadsheet on the class rules and also saved in the files section.
The replacement rudder I got from IdaSailor after my 2008 Block Island storm damage was ~ $2,100
Re: Rudder [Re: Steve Buzbee] #15315
11/05/13 12:57 PM
11/05/13 12:57 PM
Westfield, NJ
dennejo Offline
dennejo  Offline
Westfield, NJ
Steve,
Bengt's set of templates has the rudder template. I will be handing these off to Michael soon so he can do Vee Jay.
JDD
Re: Rudder [Re: Steve Buzbee] #15317
11/06/13 01:03 PM
11/06/13 01:03 PM
Highland Park, NJ
Highland Park, NJ
Hey John-
Any chance you will be at the yard over the weekend? I'd love to check my rudder shape asap so I can determine how much work I have to do...
Re: Rudder [Re: Steve Buzbee] #15321
11/06/13 09:14 PM
11/06/13 09:14 PM
Westfield, NJ
dennejo Offline
dennejo  Offline
Westfield, NJ
Take a look at the photo of the rudder.
Re: Rudder [Re: Steve Buzbee] #15358
12/16/13 12:14 PM
12/16/13 12:14 PM
San Francisco
alx Offline
alx  Offline
San Francisco
I paid about $2,300 plus shipping for a balanced rudder from Competition Composites. They say it's class legal (same surface area) but I haven't checked.
I've only been out with it once and it's made a huge improvement in the helm on Ananda.
Re: Rudder [Re: Steve Buzbee] #15362
12/16/13 02:13 PM
12/16/13 02:13 PM
Alex,
The balanced rudder is NOT class legal and has been discussed at length previously in the forum. It does not conform to the profile in the class specs. You can see at this link that the leading edge is a straight line for the class legal rudder. The balanced rudder leading edge is more forward of the pivot, resulting in the balancing effect. I've sailed boats with the balanced rudder and personally, do not like it because you loose the feel of the helm. That helm pressure is what tells you that sail adjustments are needed! The only benefit would be reduced pressure on a beam reach where there is lots of pressure in a strong breeze.
Re: Rudder [Re: Steve Buzbee] #16522
10/23/15 04:41 PM
10/23/15 04:41 PM
Belmont, MA
G
Georges Offline
Georges  Offline
G
Belmont, MA
As part of fixing my rudder damaged trailing edge, I went to build a template with dimension mentioned in the by law - with a small front leading hook similar to the keel template one.
The catch is that the template is at the minimum legal dimension. A +2mm thick (probably more for mine) profile, like my current rudder, does not fit -at all- in the template.
How can a template calibrated for minimum size be used to measure a legal profile that does not fit at all in it?
Could it be that the measurer has template with the max allowed size rather?
Sorry for the naive question - first time I am playing with template...
Cheers,
-- Georges
Re: Rudder [Re: Steve Buzbee] #16523
10/23/15 06:00 PM
10/23/15 06:00 PM
Georges,
You may fabricate a template from cardboard that is 2mm larger by starting with the minimum, then trace a pencil line 2mm outside that line. Use a razor knife to cut along the new line.
Re: Rudder [Re: Steve Buzbee] #16540
10/26/15 10:03 PM
10/26/15 10:03 PM
Belmont, MA
G
Georges Offline
Georges  Offline
G
Belmont, MA
Was on my way to do this. Wanted some feedback before redoing the template for the third time smile thanks Bill appreciated.
-- Georges
0 registered members (), 37 guests, and 0 spiders.
First cruise
COMPLETE SET OF UPPER/LOWER RUDDER GUDGEONS, PINS $325.00
by Rhapsody #348. 01/16/21 06:55 PM
by B Davis. 01/16/21 03:24 PM
Introduction and Asking for Advice
by neumannaudio. 01/15/21 04:00 PM
Wanted - Triple Deck Organizer - Found One
by B Davis. 01/05/21 03:36 PM
Stern Perch Seats
by Michael L. 01/05/21 09:19 AM
prebend
by Claribertz. 12/30/20 03:43 AM
Winter boat cover
by Gene A Trentham. 12/18/20 03:37 PM
Engine Housing Access Hatch
by Michael L. 12/18/20 03:32 PM
Aluminium Spinnaker Pole
by Michael L. 12/18/20 02:17 PM
