Topics3,769
Posts18,395
Members927
Most Online223 Dec 17th, 2019
Re: Rudder
[Re: Steve Buzbee]
#15309
11/04/13 03:37 PM
11/04/13 03:37 PM
Posts: 2,609 Portsmouth, RI
Rhapsody #348
Steve, You can create a template pretty easily using the excel spreadsheet on the class rules and also saved in the files section. The replacement rudder I got from IdaSailor after my 2008 Block Island storm damage was ~ $2,100
Re: Rudder
[Re: Steve Buzbee]
#15362
12/16/13 02:13 PM
12/16/13 02:13 PM
Rhapsody #348
Alex, The balanced rudder is NOT class legal and has been discussed at length previously in the forum. It does not conform to the profile in the class specs. You can see at this link that the leading edge is a straight line for the class legal rudder. The balanced rudder leading edge is more forward of the pivot, resulting in the balancing effect. I've sailed boats with the balanced rudder and personally, do not like it because you loose the feel of the helm. That helm pressure is what tells you that sail adjustments are needed! The only benefit would be reduced pressure on a beam reach where there is lots of pressure in a strong breeze.
Re: Rudder
[Re: Steve Buzbee]
#16522
10/23/15 04:41 PM
10/23/15 04:41 PM
Posts: 69 Belmont, MA
Georges
Belmont, MA
As part of fixing my rudder damaged trailing edge, I went to build a template with dimension mentioned in the by law - with a small front leading hook similar to the keel template one.
The catch is that the template is at the minimum legal dimension. A +2mm thick (probably more for mine) profile, like my current rudder, does not fit -at all- in the template.
How can a template calibrated for minimum size be used to measure a legal profile that does not fit at all in it?
Could it be that the measurer has template with the max allowed size rather? Sorry for the naive question - first time I am playing with template... Cheers,
Re: Rudder
[Re: Steve Buzbee]
#16540
10/26/15 10:03 PM
10/26/15 10:03 PM
Georges
Belmont, MA
Was on my way to do this. Wanted some feedback before redoing the template for the third time  thanks Bill appreciated.
39
guests, and 0
prebend
by Claribertz. 12/30/20 03:43 AM
