proposed changes for Spinnakers to allow for a 0.5 oz
#16555
11/01/15 10:13 AM
11/01/15 10:13 AM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
I hereby propose that the J/30 Class Rules be amended as follows: 1) "Rule 5.12.6 Spinnaker" be amended to read "Rule 5.12.6 Spinnakers" 2) Rule 5.12.6.1 be amended to read "Two primary spinnakers may be carried, one of minimum cloth weight 40 grams or 0.75 oz. nominal and 0.9 oz. actual weight, and one 32 grams or 0.5 oz. nominal and 0.7 oz. actual weight. Spinnakers must be made of nylon. Airex 650 is one of several approved cloths that meet the 0.75 oz. requirement, Airex 500 is one of several approved cloths that meet the 0.50 oz. requirement." 3) Rule 6.2.1. be amended to read "The number of sails on board during a regatta series or race shall be a minimum of four: #1 and #3 genoas, mainsail and 0.75 oz. spinnaker. Two additional spinnakers may be carried: a 0.5 oz spinnaker which may be used at owners discretion, and a backup 0.75 oz which can be carried, but only may be used if the primary .75 oz. spinnaker is damaged. The #2 is optional." 4) Rule 6.2.4 be amended to read ": "Except as provided herein, each class sail may be replaced a maximum of once in a calendar year; spinnaker purchases are limited to one per calendar year (One .5 and one .75 may be purchased in the first year of this rule change) . If a new sail is damaged beyond repair, it may be replaced only with the approval of the local fleet governing body. Local fleets may further limit replacement of sails and restrict the use of old sails after they are replaced." Rationale: 1) The J/30 is notoriously speed challenged in light conditions. Having the option of a 0.5 oz. spinnaker in light conditions would improve the quality of the one design competition by keeping some races from devolving into drifters, in which finish order is often based on luck. 2) As the fleet has aged, more boats spend a greater proportion of the time racing in PHRF handicap fleets. Having a 0.5 oz. spinnaker will improve the competitiveness of the J/30 in light air PHRF racing, which should make the boat more attractive to purchase for PHRF racing (as well as making the boat more fun to sail in light air). 3) By limiting spinnaker purchases to one per season, this change would not have an impact on the cost of ownership, while still adding to performance as noted above. Implementation: This rule change would take effect for the 2016 season Charlie Stoddard J30 Class Measurer
Charlie Stoddard Falcon #229
Re: proposed changes for Spinnakers to allow for a 0.5 oz
[Re: cstoddard]
#16557
11/02/15 09:00 AM
11/02/15 09:00 AM
Posts: 135 Summit, NJ
Michael L
Summit, NJ
I second the proposal.
It's an important change among a couple of things I think we should do to make us more competitive in PHRF including: - ditching the oven rule - allowing movable jib cars - removing the restriction on mainsail cloth.
BTW I dislike PHRF racing but its probably what most of us do, most of the time.
Michael
[Re: cstoddard]
#16563
11/03/15 03:37 PM
11/03/15 03:37 PM
Michael L
Summit, NJ
What is the process to rule on this?
Michael
[Re: cstoddard]
#16565
11/03/15 07:25 PM
11/03/15 07:25 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Michael, Class rules paragraph 1.7 states: 1.7 These Class Rules may be amended, altered, added to, or repealed by a majority of the members of the Board of Governors present and voting at a meeting called for such purpose on at least 30 days notice. A quorum shall consist of 40% of the Governors who were serving at the time of the notice, and no action shall be taken without a quorum. The way it has worked in the past is the District Governors get inputs from their constituents and vote at a properly called election. Since this was an action from the BOG meeting held 24 Sept at the NAs in Marion, the Class Measurer posted the proposed rule change for the class to comment on. A special meeting of the BOG will be scheduled to hold an election.
[Re: cstoddard]
#16567
11/04/15 12:32 PM
11/04/15 12:32 PM
Posts: 393 Rockwood, MI, USA
Russ Atkinson
Rockwood, MI, USA
I had forgotten about the PHRF one design rule in your area. I looked it up awhile ago and understand your issue - though I believe it to be only a local issue - others can weigh in on that one
My concern is that it appears that J/30 one design racing will continue to decline I.E nationals. Adding another sail to the inventory for one design will increase the cost and potentially further deter involvement. I think I am qualified to say I'm invested in one design, 4 nationals, 2 mid winters (800-1000 mi one way trips). The cost for me is huge already; an extra main - my choice, maintaining an inventory of good sails for 1 design, a trailer, vehicle to tow it, cost of transporting the boat across country (fuel-permits-time $2-3k transport cost each trip). I really don't want to have to buy another sail
Further, as mentioned, I have a 1/2 oz kite, sail in a light air arena, and hardly ever use it. Not sure I'd buy another for PHRF racing
Bottom line I don't want to and won't fight this fight. I'm committed to one design, you bums are like heroin dealers, I'm hooked. I'm 68 on a fixed income now and not sure how many more nationals I have left - need you folks to go easy on me
44
guests, and 14
