977,515 Dacron Main
163,063 Ananda's Refit
Re: Spin Sheave Replacement [Re: Chris_Kirstin] #16633
11/28/15 09:22 AM
11/28/15 09:22 AM
Josh - Rigrite is the only game in town....
Re: Sheave Replacement [Re: Chris_Kirstin] #17782
04/10/18 01:57 PM
04/10/18 01:57 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
It is raining again here in Oregon so I got after another project inspecting sheaves and connecting pins on the mast. The main halyard was fine with the exception that the pin being used didn't match the sheave, so I drilled for the larger 5/16" pin and installed it. Then I went to the sheave box and as much as anything else I was curious if there was going to be corrosion from contact between the box and the mast and was happy to see that wasn't a problem. Then I noticed that the small sheave at the back was was wallowing out its holes and the pin was fused in the sheave. Reading this thread it isn't clear to me if the pins are supposed to be a friction fit with the sheave and the pins rotate in the housing, or if they are supposed to be fixed in place by the peening of the pin ends and the sheaves rotate on the pin. Since this hole is now wallowed out peening a new pin would not be effective anymore.
This sheave is spinning freely and likely not going to cause a problem in its current condition, but if there is an easy fix now would be the time to do it.
20180410_100812_resize.jpg [131.35 KBytes] - (321 downloads)
20180410_101324_resize.jpg [126.92 KBytes] - (291 downloads)
Re: Sheave Replacement [Re: Chris_Kirstin] #18882
08/16/21 12:01 PM
08/16/21 12:01 PM
Mattituck, NY
G
Gary Krogman Offline
G
Mattituck, NY
What size rope is that? 8mm?
Re: Sheave Replacement [Re: Chris_Kirstin] #18892
08/30/21 04:49 PM
08/30/21 04:49 PM
Virginia
Wind Dancer 206 Offline
Virginia
Bill K. is right about Rig-Rite being the OE game in town. Before I was waylaid for a while, I was looking to see what Zephyrweks ( https://www.zephyrwerks.com/ ) had to offer. When I get the mast down this fall, I am going to talk to them about replacement sheaves.
0 registered members (), 42 guests, and 0 spiders.
