977,822 Dacron Main
163,185 Ananda's Refit
Wanted: Pole end #16717
01/29/16 01:46 PM
01/29/16 01:46 PM
Squamish, British Columbia
NaturalHigh Offline OP
I broke the jaw on one of my aluminimum pole ends. I am having a custom carbon pole made but it won't be ready by the beginning of this season and I still want my aluminum for back up and practice.
It is one of the old alumnimum pole ends that is an odd size (possibly from Hall spars?): 68 mm inside diameter (~2 11/16"), 73mm (2 7/8) OD.
If anyone has any of these old ends laying around, or is willing to take them off an old pole, let me know.
Thanks!
Scott
Re: Wanted: Pole end [Re: NaturalHigh] #16718
01/29/16 01:54 PM
01/29/16 01:54 PM
Oops, totally put this in the wrong forum! Can one of the mods move it over to the wanted forum?
Thanks
Re: Wanted: Pole end [Re: NaturalHigh] #16720
01/29/16 02:27 PM
01/29/16 02:27 PM
Scott,
I have in my basement a used Forespar Ultra UXP-250 fitting #304050
It fits a tube with 1.87" ID. You could use this and have a piece of Delrin turned in a lathe to make a sleeve for the aluminum pole. It will need new Amsteel loops installed.
You can have it for $50 plus shipping.
ps - you can also make the sleeve with raw Delrin stock and a drill using two circle cutters. Drill the outside diameter first, then drill the inside diameter.
forespar-304054.jpg [58.48 KBytes] - (183 downloads)
Forespar End Fitting
