aging aluminum
#16783
03/17/16 11:46 PM
03/17/16 11:46 PM
Posts: 164 Portland, ME
JBiermann
Portland, ME
So the shrink wrap came off today and the maintenance/upgrade slog has begun. My early spring projects includes rebuilding the boom. Aluminum corrosion has begun to be a bit noticeable especially on the boom ends, the out-haul blocks need to be replaced and I want to replace the out-haul cable with line. The boom itself seems in good shape but some corrosion on the removable ends has removed some anodization.
I have removed corrosion with a wire brush and cleaned up the boom ends but what should I do to paint/protect them from continued corrosion? Thinking aluminum etching primer and enamel before re-installation?
many spring projects to go but this is a start.
Re: aging aluminum
[Re: JBiermann]
#16785
03/24/16 10:13 PM
03/24/16 10:13 PM
JBiermann
Portland, ME
So I hit the boom ends with crushed walnut from the media blaster, took care of the flecked old primer and cleaned it up pretty well. Washed and rinsed with vinegar (acid neutralizes aluminum corrosion apparently). Two coats of aluminum etching primer and three coats of flat black enamel later... it looks pretty good. I've re-installed the sheaves and now I'm attacking the corroded screws and bolts in the boom itself intending to clean it up and give it a coat of enamel as well. Most screws and bolts are corroded into place so I'm soaking them with sprays of pb blaster and wd-40. When I take the torch to them, hopefully they'll free up. The main sheet attachment half-loop bolt thingy-mabob (that's the technical term) has worn its hold into an elliptical gap so I think i'd like to either drill a new hole or use a soft tether (like the new maxi boats!) to re-secure the main sheet connection i.e. Should I pass the webbing for the soft tether through the worn holes or over the boom itself? Just thinking out loud
Re: aging aluminum
[Re: JBiermann]
#16796
03/29/16 12:05 PM
03/29/16 12:05 PM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
Project looks good, by all means eliminate the wire and use 12 strand Dyneema for the outhaul tail. Invest in some small blocks to increase the outhaul purchase. I took Bill's advice years back in my Boom Bail makeover. As for the webbing straps, no personal experience but I saw these a few years back and thought Dyneema Climbing Slings might be an inexpensive solution. Unclear how class rules would apply.
Re: aging aluminum
[Re: JBiermann]
#16802
04/06/16 12:44 AM
04/06/16 12:44 AM
Posts: 74 St. Helens, OR USA
Koesh
St. Helens, OR USA
I'll be converting to strap on Koesh when she goes back in. That'll be a while, though...drilled some holes to check the wet areas below the turn of the aft bilge and found compost. Got the new balsa (yeah....going back) and I'll be carving away on the outer skin as soon as it's warm and dry enough here in Oregon.
If you go to strap, a friend of mine recommends using a double figure-eight as per climbing practice for tying it in. VERY secure!
Doug Marshall Koeshtkah #207
44
guests, and 14
