Bronze Rudder Pin?
#16788
03/26/16 06:17 PM
03/26/16 06:17 PM
Posts: 36 Ottawa, Ontario, CANADA
CAN106
Perhaps the DPO replaced my pintles and gudgeons, but my rudder pins are a little smaller than RigRite thinks they should be for a j30.
Mine look like they were made of bronze, are 2cm (0.787" ... About 50/64") diameter and have a working length of about 2.75". Can't find a brand stamp on any of the rudder parts.
Will have replacements machined or find a bushing. Was wondering if there are some known variants like mine?
Corey Glynn
Re: Bronze Rudder Pin?
[Re: Rhapsody #348]
#16790
03/26/16 07:50 PM
03/26/16 07:50 PM
CAN106
Thanks Bill, helpful as always.
I can imagine the bushin pressed through the gudgeons on the rudder and the turned down pin too. What did you do with the transom gudgeons (which are still gudgeons, right....soooo confusing)?
Corey Glynn
47
guests, and 14
