mattjenPDX71, loic, Cousineddy, Captain Rick, Boat Boxer
915 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
842,376 Dacron Main
127,442 Ananda's Refit
Topics3,731
Posts18,283
Members915
Most Online223
Dec 17th, 2019
Bronze Rudder Pin? #16788
03/26/16 06:17 PM
03/26/16 06:17 PM
Ottawa, Ontario, CANADA
CAN106 Offline OP
CAN106  Offline OP
Perhaps the DPO replaced my pintles and gudgeons, but my rudder pins are a little smaller than RigRite thinks they should be for a j30.
Mine look like they were made of bronze, are 2cm (0.787" ... About 50/64") diameter and have a working length of about 2.75". Can't find a brand stamp on any of the rudder parts.
Will have replacements machined or find a bushing. Was wondering if there are some known variants like mine?
Corey Glynn
Re: Bronze Rudder Pin? [Re: CAN106] #16789
03/26/16 07:42 PM
03/26/16 07:42 PM
Corey,
The pintles and gudgeons on Rhapsody were very worn so I had a machine shop bore the gudgeons and turn down the pintles. They inserted via press fit custom marine bronze bushings to take out all the play, and also provided a spare pair of bushings that could be inserted when the originals were worn.
Happily Rhapsody's new owner has these now....
Re: Bronze Rudder Pin? [Re: Rhapsody #348] #16790
03/26/16 07:50 PM
03/26/16 07:50 PM
CAN106 Offline OP
CAN106  Offline OP
Thanks Bill, helpful as always.
I can imagine the bushin pressed through the gudgeons on the rudder and the turned down pin too. What did you do with the transom gudgeons (which are still gudgeons, right....soooo confusing)?
Corey Glynn
Re: Bronze Rudder Pin? [Re: CAN106] #16791
03/26/16 10:40 PM
03/26/16 10:40 PM
Corey - all hardware removed from rudder and transom with pins and provided to machine shop. Bushings were made for rudder side and transom side, not a single sleeve - clearance inside for slightly turned down pins.
Re: Bronze Rudder Pin? [Re: Rhapsody #348] #16792
03/27/16 08:14 AM
03/27/16 08:14 AM
CAN106 Offline OP
CAN106  Offline OP
Thanks Bill. enjoy that j/109!
Corey Glynn
0 registered members (), 25 guests, and 0 spiders.
First cruise
Hi! Anyone home?
by Cousineddy. 08/11/20 09:48 PM
Wet bulkhead
by dlabrosse. 08/04/20 12:32 PM
Shroud Tension Tuning
by usa1136. 08/02/20 11:01 AM
#484 "Conundrum" for sale
by nathankt79. 07/29/20 07:31 PM
by Koesh. 07/27/20 02:22 PM
Simple cruising douse
by Rajesh Verma. 07/20/20 07:05 AM
One of the best things about sailing offshore...
by Rajesh Verma. 07/20/20 07:04 AM
WTB: Lower Shrouds (Replacement)
by Rhapsody #348. 07/19/20 12:17 PM
3 way/Y-Valve handle
by Rhapsody #348. 07/10/20 03:53 PM
New North Main - too long?
by Georges. 07/01/20 02:27 PM
