needed - J30 Portal Window(s)
#16826
04/17/16 04:31 PM
04/17/16 04:31 PM
Posts: 12 Texas
Stuart Smith
Texas
AHOY, yesterday in high-seas the port-side-aft portal was deep-sixed when a cabin denizen head-planted it. Is one available or do I need all four?
Cheers,
Stuart Smith owner J30 Presto! hull #82 prior J30 Novia hull #3 STU_SMITH@ATT.NET
Re: needed - J30 Portal Window(s)
[Re: Stuart Smith]
#16828
04/24/16 12:17 PM
04/24/16 12:17 PM
Posts: 12 Texas
Stuart Smith
Texas
Vic,
thanks for your reply are the four portals symmetric -? you're right about the old sealant - Presto! could use a new set of 4 ...
[Re: Cap'n Vic]
#17239
04/01/17 11:33 AM
04/01/17 11:33 AM
Posts: 218 Scappoose, OR
Coastie
Scappoose, OR
It is really easy to make your own if you have a router and a pattern following bit. Use one of old port lights as the pattern. Then make sure to use a small round over bit to take the 90° off the side that gets mated to the hull.
[Re: Stuart Smith]
#17261
04/12/17 02:42 PM
04/12/17 02:42 PM
Coastie
Scappoose, OR
Just looked at the new material I have used to make the port lights and it is just under 1/4" with the protective paper still on and it matches what I removed (with the exception that you can see through the new stuff). The polycarbonate I used was easy to cut initially on the tablesaw and then finish with the pattern following router bit. The plastics place I bought the material from says they use routers almost exclusively to cut these materials, which kind of surprised me. I would have thought the router bits would tend to burn or melt the plastic.
47
guests, and 1
spider. |
