Re: "shafted"
[Re: Russ Atkinson]
#16854
05/20/16 04:58 PM
05/20/16 04:58 PM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
Have them take a flat bar drill a thru hole and then weld a nut in then two more holes to line up with the flange
This will make up a short puller with a bolt in the nut
This worked well for me
Charlie Stoddard Falcon #229
Re: "shafted"
[Re: the redhead]
#16855
05/21/16 01:50 PM
05/21/16 01:50 PM
Posts: 203 Oxford, MI
Conundrum
Oxford, MI
I used something like a dent puller. Screws Onto the end of the shaft AND HAS A SLIDE HAMMER ON IT. THE SLIDE SLAMS IN THE PROPER DIRECTION AND IN ALIGNMENT OF THE SHAFT THE RUDDER WAS REMOVED TOO. AND that's VERY EASY!
35
guests, and 1
spider. |
