• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » More questions...
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#1686 - 08/21/02 12:20 AM More questions...
I am so greatful for all your help and advice and I promise someday I will quit asking for it!
Next problem...
I have no masthead VHF antenna, or masthead light, and my wind instrument keeps falling off (poor bracket attachment).
Would I be better off waiting until I pull her for the season, drop the mast and work on the it then, or can I just string all the new electrical down the mast and attach brackets, and if so, any tips?
I'm looking for types of brackets, mounting hardware (screws vs. bolts,)where I can get them, and those sorts of things...
Jay
Canm you tell I'm a rookie boat owner?
Top
#1687 - 08/21/02 02:42 PM Re: More questions...
dwl Offline
Loc: New York, NY, USA
Don't have a strong opinion about the rest, but... If you don't need it, you might well consider simply relocating the VHF antenna to the stern rail, and pulling the coax out of the mast. You lose a fair bit of line of site range on the VHF, but you also shed the weight of the antenna, (including, in particular, the coil) and the weight of the cable in the mast. All weight right where you don't want it.
- David
Top
#1688 - 08/22/02 09:55 AM Re: More questions...
Brad Stokes Offline
Loc: Corpus Christi, TX
You'll probably want the mast down to string electrical and VHF if you're going to do it, because you'll have a heck of a time getting the wires out of the mast at the bottom.
I'm not sure the J/30 came standard with a masthead light, maybe on some. Mine didn't have one when I purchased it. I added a small windex light to illuminate the windex at night. Because it has a very low amperage bulb, I was able to use a smaller (and lighter)gauge wire and still not have unacceptable voltage drop (no greater than 2%).
My VHF bracket is attached with rivets. I don't know how your windex is attached but the windex should screw into the masthead crane. Mine has two threaded holes in the crane and the windex screws into the aft hole. If you have a wind instrument (ie, an anemometer)I'm not sure how that attaches, as different manufacturers have different methods. I would bolt vs screw and would use threadlock or locking washers. Stainless of course.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 7 Guests and 2 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
