977,822 Dacron Main
163,185 Ananda's Refit
Fuel Filter and Water Seperator #16888
06/26/16 06:34 PM
06/26/16 06:34 PM
New Orleans, LA, USA
David Erwin Offline OP
Anyone have a recommended Raycore part number to replace the factory fuel filter? Installation pictures welcome... :>)
Re: Fuel Filter and Water Seperator [Re: David Erwin] #16889
06/27/16 08:41 AM
06/27/16 08:41 AM
There are various external filters on the engines and these are not standard Yanmar parts. If you mean the external filter and housing use a Racor spin-on cartridge and housing with the integral pump for priming. The model of the housing I prefer is R215R2. Available from West Marine, Amazon, eBay, etc. I recommend using the R15T 10 micron spin on element for this.
The Yanmar engines have a 2 micron cartridge mounted on the engine just above the high pressure fuel pump. I use the original Yanmar filter elements and replace the o-ring on the housing cover. Yanmar Fuel Filter 104500-55710 and Yanmar Fuel Filter canister O-ring 24341-000440
Re: Fuel Filter and Water Seperator [Re: David Erwin] #16890
06/27/16 10:28 AM
06/27/16 10:28 AM
Perfect and thanks. Yes, I want to replace the entire assembly.
Re: Fuel Filter and Water Seperator [Re: David Erwin] #16893
06/29/16 09:34 AM
06/29/16 09:34 AM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
Dave - if you are replacing the Yanmar fuel filter assembly, don't forget to replace the copper washer/gadgets too
Re: Fuel Filter and Water Seperator [Re: Russ Atkinson] #16895
07/02/16 02:08 PM
07/02/16 02:08 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
I second Bill's recommendation for the Racor unit with priming pump.
