Barient 21 secondaries
#16936
08/22/16 03:32 PM
08/22/16 03:32 PM
Posts: 3 Mandeville, Louisiana
KarlB
I need to replace the barrel on a Barient 21 secondary. Barient being out of business that part is no longer available and I haven't been able to find a used 21 with same 5 bolt mounting pattern.
I'm trying to avoid drilling more holes,that being the case does anyone know which if any Harken, Lewmar etc. winches may have the same mounting bolt pattern as this Barient.
Thanks, Karl Bourque Black Magic #428
48
guests, and 0
