977,723 Dacron Main
163,137 Ananda's Refit
Trailering Measurments #16982
09/29/16 11:37 AM
09/29/16 11:37 AM
Richmod, VA
Phil Offline OP
Phil  Offline OP
Richmod, VA
Looking to trailer a J30 using a trailer with fixed bunks rather than pads. What is the distance from the bottom of the boat a spot 28 inches back from the keel, to the bottom of the keel? This is where the bunks will settle, about 56"s apart.
Re: Trailering Measurments [Re: Phil] #16989
10/05/16 12:15 AM
10/05/16 12:15 AM
Oswego, NY USA
Crusader586 Offline
J/30 BOG Member
Crusader586  Offline
J/30 BOG Member
Oswego, NY USA
Not sure if this is to late or not. My trailer is custom built from a mobile home trailer. Keel is 8 inches from the road surface. Bunks are adjustable for height. Currently stern is 50 inches to bottom of keel and forward is 53.
I will post some pictures later so you have a frame of reference.
0 registered members (), 45 guests, and 0 spiders.
