978,284 Dacron Main
163,310 Ananda's Refit
J29/J30 Frac rig spinnaker differences #17081
01/10/17 09:22 PM
01/10/17 09:22 PM
Brantford Ontario
Faster_K_Yote Offline OP
Brantford Ontario
Comparing used fractional rig J29/J30 Spinnakers at Bacon Sails. Why would the spinnakers be different between the two boats, they are virtually the same boat, almost identical rigs. The J29 spinnakers are bigger and more abundant than the J30 spins.
My apologies if this has been covered already.
Re: J29/J30 Frac rig spinnaker differences [Re: Faster_K_Yote] #17082
01/11/17 08:03 PM
01/11/17 08:03 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
There are 2 flavors of rigs on J/29... Masthead and Frac. The Frac is pretty close to a J/30.
Dennis Bartley
Planxty, s/n 23994
hull 205
0 registered members (), 41 guests, and 14 spiders.
