After spending some quality time rebuilding the water pump I then spent some time with the 4" grinder removing more bottom paint, gel coat and blisters. I thought it was interesting that blisters I had ground into last Thursday were still weeping today 4 days later. These are not small blisters, when you first see them they are dime size zits, then grinding through them opens most to about a quarter size and a few as large as a silver dollar.
Doing this work gives you time to think about all your previous sins. It also made me think about if it would have been worth it to pay to get the hull sandblasted. At least in my case doing the work slowly while the boat sits here getting other things done to it only makes sense for me to do the work myself. If I were paying a yard for storage getting this serious hard work done quickly would make more than just financial sense.
The other thing that is interesting is watching the moisture readings. In some cases where the hull is dryer, 1.7 or so there have been some minor improvements over the last few weeks with the numbers moving down toward 1.5 or better in some cases. Where the readings are 3 there has been no change. The numbers are also generally better toward the waterline and worse toward the center-line. That make me think I will start my drying work at the center and then work out. To a point gravity is at work here, so if the center gets dried out I would expect the remaining moisture to want to equalize through out the core.
There is no doubt in my mind that these blisters are just one of several moisture sources into this balsa core. Fixing them permanently will be critical to the ultimate success of drying this core and then keeping it dry. But I'm also really looking forward to fairing (not) this hull again after all the nasty things that are going to have to happen to fix the soggy stuff.
