Black Stained Woodwork
#17103
02/07/17 01:03 PM
02/07/17 01:03 PM
Posts: 218 Scappoose, OR
Coastie
Scappoose, OR
I have started spending some quality time back up inside MaJic Carpet and have been sorting out various issues I plan to deal with soon. One thing that has my attention are the several places that the woodwork has become black stained from leaks in the deck, windows hatches etc. These aren't horrible by any means, but they are unsightly. As a woodworker I know these stains don't just sand out. So the options as I see them are: 1) Ignore them 2) Use a pigment paint or a very dark stain and paint the woodwork 3) Replace the stained wood Am I missing any options?
Inspecting up under the gunnels shows both the toe rail and stanchion bolts are prime contributors of the moisture that caused most of these problems, so for sure I will address them.
Re: Black Stained Woodwork
[Re: Coastie]
#17122
02/19/17 02:35 PM
02/19/17 02:35 PM
Coastie
Scappoose, OR
That may be a realistic approach to toe rail leak problem. My toe rails visually look ok and I know any effort to get underneath them means destroying them. But the leaks have to go.
51
guests, and 0
