Topics3,779
Posts18,438
Members932
Most Online223 Dec 17th, 2019
source for masthead/base sheaves and t-ball plugs
#17131
02/22/17 11:50 PM
02/22/17 11:50 PM
Posts: 33 Lincoln, NE
jheinzle
Lincoln, NE
If any of you are sick of dealing with rig-rite's attitude and crappy customer service, I think I've found another source for the hard-to-find masthead & turning block sheaves. And it appears they are about half price. Masthead DH 002 Sheave Aluminum, 1-3/4" Diameter, 1/2" Thick, Stainless Steel Bushed for 1/4" Pin or Bolt. (I plan to drill one of to 5/16" I.D. for the inner sheave. the outer uses a 1/4" I.D.) Base DH 006 Sheave Aluminum, 2-1/2" Diameter, 5/8" Thick, Stainless Steel Bushed for 3/8" Pin or Bolt. (I plan to drill this to the 1/2" I.D. needed on my stock 1979 turning block on the mast base) http://www.downwindmarine.com/Dwyer-Aluminum-Sheaves-p-90890670.htmlIf you don't like aluminum they have a delrin version that may work DH 003 Sheave Delrin 1-1/2" Diameter, 7/16" Thick, Stainless Steel Bushed for 1/4" Pin or Bolt. Hayn SHRPM07 t-ball plug http://www.downwindmarine.com/Hayn-T-Bar-Backing-Plate-Retaining-Plugs-Rubber-p-91003591.htmlI called Rig-Rite to place an order and got the worst service considering I was trying so hard to buy these parts from them. I later called back and cancelled my order vowing to never order from them again. Joe
Re: source for masthead/base sheaves and t-ball plugs
[Re: jheinzle]
#17293
04/28/17 07:20 PM
04/28/17 07:20 PM
Posts: 164 Portland, ME
JBiermann
Portland, ME
alright, anybody's sheave box have the little sheaves behind the big ones? Where do I find these? I'm missing a "leader" sheave and pin all together!
33
guests, and 0
