Instrument Beautification
#17227
03/29/17 01:00 AM
03/29/17 01:00 AM
Posts: 125 San Francisco
alx
San Francisco
Ananda's bulkhead mounted instruments are quite functional, but come up pretty short in the aesthetics department: They're not terrible, but the variety of backing materials used to mount them (usually whatever I had on hand) and the fiberglass behind them in general doesn't really give them the professional, polished look and feel that I'd like. So I decided to up the ante a little, and am fabricating teak plates that will mount on my bulkheads and give the instruments a little nicer of a backdrop. Here's one such plate after rough fitting: And here's the pair after finishing in the woodshop: The edges are nicely rounded to meet flush with the bulkhead: I figured I'd make a thread about this project as progress is starting to come more quickly. Sometime in the next few weekends, these will be installed, holes cut, and the instruments mounted. Stay tuned!
Re: Instrument Beautification
[Re: alx]
#17229
03/29/17 02:22 PM
03/29/17 02:22 PM
alx
San Francisco
It'll be treated with Cetol, matching the toerail trim, grabrails, and the companionway hatch boards (as seen in the first picture). I agree that the teak maintenance is a pain, that's why I don't do it I hired a guy to redo the wood every year. The boat always looks great and I don't have to lift a brush!
[Re: alx]
#17301
05/08/17 11:43 AM
05/08/17 11:43 AM
alx
San Francisco
After 2 weekends of epoxying, drilling, filling, re-drilling, sanding, cutting, and sealing, the plates and boat have been united. They're ready for varnish (Cetol) and then mounting the instruments! Once I had all the holes drilled, I test-fit them with all the screws in and had to step back and admire my handiwork for a few minutes. Then I took a deep breath, picked up the hole saw and carved them up! They're sealed with butyl tape around the top 3 edges and around the edges of each cutout in the bulkhead. All bulkhead cutouts have the balsa core dug out at least 1/4" and sealed with MarineTex epoxy. Each panel mounts to the bulkhead with a grid of 9 screws, and each screw hole was overdrilled, filled with epoxy, and the epoxy drilled to protect the bulkhead core. Here's how it looked in the end, with small teak caps inserted for each screw hole and sanded to a flush finish with 220 grit. Next step - Cetol varnish to match the rest of the wood trim on the boat! Bonus shot: test-fitting the speakers and a new Axiom chartplotter. The only thing I'm not happy with is the bottom of the panel doesn't parallel the deck - when I mounted them I decided paralleling the companionway edges was visually more important. It definitely passes the 10' test, though, and even at 3' unless you're looking directly on, it's not noticeable. Expect more pics after Cetol and instrument mounting!
[Re: alx]
#17307
05/14/17 01:55 PM
05/14/17 01:55 PM
alx
San Francisco
Project status: finished! When I got to the boat this weekend, the boards looked amazing after several coats of Cetol: I set to work mounting all the instruments. Per Bill's suggestion, I managed to acquire black speakers. Here the port side is all installed: Wiring was a little challenging - the Axiom requires an adaptor cable to convert from N2K to SeatalkNG for the instrument network, which meant the cable length was fixed. I had to redesign things a bit, and move a network block closer to the plotter. Here's the back with all wires hooked up: And underneath, where the new network block ended up: Starboard side got a new i70s to mirror the wind readout on port (sometimes crew members have a pesky habit of sitting in front of my instruments!) as well as a p70s autopilot control, now moved below the i70s: All in one frame, I think it came out looking really classy and nice: I wrapped up work in time to slip the lines for a few minutes and go out to watch the sunset: Now I have time for sailing - and more projects, of course!
52
guests, and 1
spider. |
