• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » (2) Interior gear questions
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#1726 - 01/03/09 11:55 AM (2) Interior gear questions
JBro Offline
Loc: Bainbridge Island, WA
Hi all-
Since air temp is 34deg, I'm focusing on some interior projects over the next couple months. ;-) So, does anyone have any insight/recommendations on the following:
1.) braces/support for salon table?
Someone prior to me created some funky wood-hinged supports for the drop leaves of the table. They don't work well, look bad, and need to go. I believe the original issue was a steel flip-up rod material supporting the drop leaves. Is this the case and any ideas where I could source these supports? Or, other ideas?
2.) Galley stoves for orig interior layout
The current stove is the original Seaward(?)and it needs to be replaced. I've read good things about the Origo non-pressurized stoves. While LP would be ideal, converting to that has a different level of scope. Safety #1 and usability #2 are my goals and I've heard that the Origos are really quite safe and by design, more contained that having to do everything required to run LP with all of the complexity required to do it right. Any comments incl. Origo model that fits? or experiences running LP would be fantastic.
Thanks!- Jeff
J/30 #426
_________________________
- Jeff
J/30 #426 - Watusi
Top
#1727 - 01/03/09 12:30 PM Re: (2) Interior gear questions
Class Co-President
Loc: Portsmouth, RI
Jeff - is your stove the model with the oven or just the cook top?
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#1728 - 01/03/09 02:02 PM Re: (2) Interior gear questions
JBro Offline
Sorry - should have specified - it's the cooktop. Thanks, Jeff
- Jeff
J/30 #426 - Watusi
Top
#1729 - 01/03/09 05:25 PM Re: (2) Interior gear questions
R II Offline
Loc: Bellevue, WA, USA
Quote:
Originally posted by JBro:
Hi 1.) braces/support for salon table?
2.) Galley stoves Origo non-pressurized stoves.
The leaf supports on Rauzer II are basically u-shaped rods with the tips bent at 90 degrees that fit into holes in the table tube legs.
RII has an Origo non-pressurized alcohol 2-burner stove that works well as long as you are sure to use the correct fuel. I picked up a gallon at a hardware store that made the pots very sooty on the bottom and the fumes stung your eyes. It took a while using the proper fuel before all of the bad stuff was burnt away. Refilling the burners is a bit of a hastle, but if you find a bottle with a closable nipple (lamp oil bottle or dish soap bottle), you can fill that, at the dock and refill the burner underway pretty easily. Slopping it in from a wide mouth container is messy. I have propane for the cabin heater and would prefer to have a propane stove, but the cost and hastle of running another line makes the current stove adequate.
AC s/v Rauzer II #448
[This message has been edited by alcal1750 (edited 01-03-2009).]
AC
Top
#1730 - 01/03/09 09:43 PM Re: (2) Interior gear questions
Class Co-President
Loc: Portsmouth, RI
Jeff - if you want to stick with the "original" stuff, look at the Seaward website at this link and see if they have a suitable replacement. http://www.seawardproducts.com/ (look on left menu Gas Stoves)
I have a different solution on Rhapsody. We have one of the single burner omelet stoves you see in restaurants bolted to the underside of the wooden cutting board. This is flipped over when we want to use the stove. It uses disposable butane cartridges and doesn't have the hassle of the propane locker, plumbing and solenoid valve. Whenever we cruise I just pack a few butane canisters. They are light and easy to pack.
If you go the Origo route, the Model 4000 is supposed to be as close to a drop in replacement that you can find. The non-pressurized alcohol stoves are pretty good. I'd stay away from any of the pressurized alcohol units. I've used them on other boats and they are a pain in the neck.
Bill
Bill Kneller
Rhapsody J/30 #348
Top
#1731 - 01/04/09 06:15 AM Re: (2) Interior gear questions
Black Knight Offline
Loc: Panama
I use the Origo Model 4000 after replacing the pressurized alcohol stove the previous owner had on the boat in 1994. To avoid blackened pots, insure you purchase cooking alcohol, not industrial alcohol ... something I did once, much to my dismay. I am very happy with the stove and do up to three week cruising trips with this arrangement.
#237, Panama
Top
#1732 - 01/04/09 11:32 AM Re: (2) Interior gear questions
sonskyn Offline
Loc: Apponaug Rhode Island
swego has a special on the cookmate replacement stove some modification will have to be made to the existing cutout as the cookmate is approx 1.5" smaller than the original kenyon stove in both directions http://www.swego.com/store/pc/viewPrd.asp?idcategory=12&idproduct=5
Top
#1733 - 01/05/09 02:28 PM Re: (2) Interior gear questions
JBro Offline
First off - thanks everyone for the great responses and input. I can't say enough how fantastic this community is.
I think I'll go the Origo route. Doing the whole LP thing is sure a nice end result but effort vs. return seems too high (if I had the newer design with stove/oven range, probably a different story though). Great tips WRT to the type of alcohol to use.
I'll check out the Swego site and also check out the upcoming boatshow for specials... I'll do my best to try to document the changeover and post the steps back to the forum.
Thanks again all!
- Jeff
#426
- Jeff
J/30 #426 - Watusi
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 7 Guests and 2 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
