978,160 Dacron Main
163,279 Ananda's Refit
Replace seacocks? #17284
04/24/17 04:23 PM
04/24/17 04:23 PM
Bermuda
Sean Offline OP
Sean  Offline OP
Bermuda
Hi,
It looks like my boat has the original seacocks which I believe are seized.
Correct me if I'm wrong but these are all one piece, valve and threwhull is this correct? (See URL for pic)
https://goo.gl/photos/EruuvaACKNBxAE596
Re: Replace seacocks? [Re: Sean] #17288
04/24/17 11:20 PM
04/24/17 11:20 PM
Westerly, RI
Chris623 Offline
Chris623  Offline
Westerly, RI
Hi Sean,
Assuming that the bronze hasn't turned pink deep into the metal, these Perko seacocks are rebuildable. The parts needed are:
080500599B Perko Repair kit - 3/4
080500599C Perko Ball Valve Stem (driver)
which are available by special order from Jamestown Distributors, Yacht Supply Depot and others.
I had good luck rebuilding mine, and found that the replacement parts were better than the original.
-Chris
Re: Replace seacocks? [Re: Sean] #17290
04/25/17 08:25 PM
04/25/17 08:25 PM
Portland, ME
JBiermann Offline
JBiermann  Offline
Portland, ME
you may think they're seized... a bit of lubricant and a pipe for leverage might disagree...
0 registered members (), 49 guests, and 1 spider.
