January
nye87, Killian, newbie_owner, Fred Schroth, Salish Sea Benji
860 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
744,221 Dacron Main
Topics3,618
Posts17,863
Members860
Most Online104
Feb 12th, 2014
Page 3 of 3 1 2 3
Re: Common Ground [Re: Coastie] #17537
11/13/17 06:48 PM
11/13/17 06:48 PM
Dave - looks great! Did you get one of the Paneltronics J/30 electrical panels as part of your electrical upgrade?
Re: Common Ground [Re: Coastie] #17538
11/13/17 07:33 PM
11/13/17 07:33 PM
Scappoose, OR
Coastie Offline OP
Coastie  Offline OP
Scappoose, OR
Bill,
I tried to get the Paneltronics panel that you spec'd out when I first started this project, but it wasn't available. I have the Blue Seas:
Blue Seas Panel
It seems to be pretty close to your setup and I get a small discount when I buy at Fisheries Supply.
In the existing wiring arrangement most of the cabling is down the sides of the hull. SInce I have easy access to the center below the sole I am really inclined to run my lines there. If the lines are off the bottom of the boat and high and dry, is there any reason to not use this avenue? I have way better access with the center of my sole removed then trying to neatly get these lines in behind the cabinets.
Page 3 of 3 1 2 3
0 registered members (), 16 guests, and 0 spiders.
First cruise
HURRICANE HARVEY WIND SEED
1983 J/30 Hull #427 Taku
by nathankt79. 01/23/19 09:18 AM
2019 NA's
by David Erwin. 01/21/19 11:02 AM
ORRez
by nathankt79. 01/17/19 10:20 AM
Spinnaker Pole End
by Rob Van Name. 01/15/19 04:41 PM
Prop selection help
by nathankt79. 01/15/19 02:43 PM
For Sale - Screamin' O #35
by jheinzle. 01/05/19 04:30 PM
J/30 Class is now a West Marine affiliate
by Bickertp45. 01/03/19 02:56 AM
J 30 for sale
by nathankt79. 12/26/18 02:06 PM
Stress Cracks from Accident
by nathankt79. 12/18/18 04:36 PM
