June
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Benz @ North, David Hulse, littoraldrift, Windchill, knh555
1001 Registered Users
956,033 Dacron Main
156,472 Ananda's Refit
Topics3,945
Posts18,946
Members1,002
Most Online223
Dec 17th, 2019
Max Luff of Blade #17569
12/13/17 10:25 PM
12/13/17 10:25 PM
MD
U
usa1136 Offline OP
usa1136  Offline OP
U
MD
Just curious if anyone knows the background of why the maximum luff on the blade is a full 6" shorter than the max luff on the genoa. Seems odd since most if not all competitive boats have done away with the #2, why the class rules would limit the potential size of the #3 creating a larger span in sail area from the #1 to #3.
Re: Max Luff of Blade [Re: usa1136] #17570
12/14/17 08:38 AM
12/14/17 08:38 AM
The #3 sail plan was intended to depower the boat in big air. Going to full hoist height adds sail area at the top and provides more heel which is undesirable. Some use a #2 for a transition between the #1 and #3, but is has a very narrow effective wind range. Fully crewed, the #1 / #3 sail combination works for most boats that can swap headsails.
Ironically, the older boats such as the J/30 were designed with big overlapping headsails. Many of the newer boats (e.g. my J/109) were designed with non-overlapping headsails. For PHRF, I get trounced if I use the OD rating and the wind is less than 10 kts. I have a rating with a 145% genoa that keeps the boat competitive in light air at a cost of 3 seconds per mile.
Re: Max Luff of Blade [Re: usa1136] #17572
12/14/17 02:11 PM
12/14/17 02:11 PM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
Past president John McArthur had the same idea several years ago and it was discussed during a BOG meeting. If I recall correctly, Rod Johnstone advised against a longer luff on the #3 from a design perspective and similar point of view to that expressed above by Bill.
Moderated by  LChristy
0 registered members (), 40 guests, and 0 spiders.
First cruise
Spinnaker Mast Track Needed
by pez. 06/08/23 05:55 PM
Zephyr V2.0 For Sale
by Breezin454. 06/06/23 03:08 PM
Sliding hatch channel source
by Breezin454. 06/04/23 08:31 PM
Replacement table legs
by Navy Dan. 06/04/23 06:12 PM
Fuel tank replacement
by Navy Dan. 06/02/23 05:52 PM
Dockline fairleads
by Patrick Stinson. 05/30/23 09:02 PM
Barber hauler
by Navy Dan. 05/29/23 07:13 PM
Head door
by Steve Buzbee. 05/23/23 05:49 PM
For Sale: 1982 (Hull 434) "ENCOUNTER"
by David Hulse. 05/19/23 09:42 AM
