978,305 Dacron Main
163,315 Ananda's Refit
Re: Examine the chainplates [Re: Sean] #17588
01/04/18 07:44 PM
01/04/18 07:44 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
Was up in the boat this afternoon with the moisture meter and for once things have gone my way. The area directly behind the chainplates is dry. The area is ugly to look at though. I didn't poke around, but this almost seemed like it might be a plywood bulkhead, rather than one that is balsa cored. Could that be the case? Since it is dry my plan is to swab some slightly thickened epoxy around in the bolt holes, but that is it. I will inspect around the hole through the deck more too when the tarp is off again, but the surveyor hadn't marked that area up.
20180104_150017_resize.jpg [980.74 KBytes] - (467 downloads)
Re: Examine the chainplates [Re: Sean] #17593
01/06/18 05:34 PM
01/06/18 05:34 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
When I replaced my chain plates last year my shop salvaged the old chain plates to become chain plate backing plates. Mine weren't too bad either but they had served for 35 years. One less thing to worry about. My bulkhead and deck were dry thankfully.
Re: Examine the chainplates [Re: Sean] #17594
01/06/18 07:52 PM
01/06/18 07:52 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
My fab shop is doing that for me now with the old chainplates. What still surprised me was that the sealer around the chainplate had become so brittle, it was almost dust. Equally amazing is that in that condition it was still keeping water out (or maybe it wasn't anymore). I would venture that 3M 5200 was used originally or something similar. I wonder if the chainplates heating up in the sun over many years may have totally baked the sealer?
Re: Examine the chainplates [Re: Coastie] #17764
03/20/18 01:45 AM
03/20/18 01:45 AM
Vancouver, BC, Canada
dlabrosse Offline
dlabrosse  Offline
Yes there is a triangular area around the chainplates that is made from plywood while the rest of the bulkhead is balsa. My portside bulkhead is rotten and is going in for repairs later this week.
Dominique Labrosse
Red Five, #92
Re: Examine the chainplates [Re: Sean] #17765
03/20/18 02:00 AM
03/20/18 02:00 AM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
I swear the portside of these boats was made by the night crew while they smoked weed or something. Everything is worse on the portside of my boat.
Re: Examine the chainplates [Re: Sean] #17767
03/20/18 11:10 AM
03/20/18 11:10 AM
On Rhapsody it must have been the same crew on topside port, and below the waterline on starboard. I saw a J/109 having core work done at International Marine because it failed an inspection survey on a sale pending last year. You could see a greasy footprint on top of the balsa core on the port side next to the engine where it delaminated. That's just carelessness.
Re: Examine the chainplates [Re: Sean] #17768
03/20/18 12:01 PM
03/20/18 12:01 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
I come from a steel manufacturing background. I get that there are a ton of variables that go into making something. One of those very big variables is the people doing the work and the care they take doing their jobs. Quality is everyone's responsibility up and down an organization. Poor work ethic and poor product doesn't happen in a vacuum.
I like to joke about what happens at night because when I worked in the field in the mines that is when most things broke. Now there were some legitimate reasons why that actually happened, but it was also the B or C crews that worked then. The capable long term folks had the day shift and there was some actual management around.
