Re: Coolant Hose 2QM15
[Re: jheinzle]
#17654
02/02/18 09:16 PM
02/02/18 09:16 PM
Posts: 11 Seattle, WA
NightOwl
Seattle, WA
When I replaced the mixing elbow on my boat I found I had a problem with the existing coolant hose (it leaked at the ends). I simply replaced it with a section of cooling hose I had available on the boat. It works just fine so far.
44
guests, and 14
