Cancelled: Hull #62 with Trailer $5,000
#17690
02/15/18 02:05 PM
02/15/18 02:05 PM
Posts: 232 Belleville, IL, USA
Mark
Belleville, IL, USA
Listing cancelled. We are parting out the boat. Mostly complete boat with trailer, St. Louis MO Sadly, I'm giving up. Hull has been re-cored around both sides of the keel, under the sink and all known wet spots. Deck as well, and every throughbolt and the chainplates have been overdrilled and epoxy filled. Bottom gel coat has been stripped and refinishing begun. Keel is stripped for templating, topsides are ready for paint. Needs a rudder and the engine needs rebuilt. Mast needs the through-bar mod. Otherwise, I believe I have everything. Also has Harken windward sheeting traveler, self tailing primaries... The trailer is a double 6,000# axel, built by a local welder who has a J30 in 2001. For good or bad, trailer is overbuilt, heavier steel than Triads. The trailer has never been registered. $5,000. You have to take everything! Contact: Mark Schnitzler mark@markschnitzler.com Tel. 314-541-1636 Ad posted 2/15/2018
Re: Hull #62 with Trailer $5,000
[Re: Mark]
#17692
02/15/18 11:46 PM
02/15/18 11:46 PM
Posts: 77 MD
usa1136
MD
39
guests, and 1
spider. |
