Chainplate Re-installation
#17695
02/18/18 06:30 PM
02/18/18 06:30 PM
Posts: 218 Scappoose, OR
Coastie
Scappoose, OR
I just was reading through a ton of old interesting threads on chainplates, but didn't quite see what I was looking for. My new chainplates are going to be finished this week and the old ones have been cut down to be used as backing plates. My bulkheads are solid, dry and do not require anything beyond being cleaned up. The only sealer before I removed these plates was in the cabin top around the chainplate, nothing below that point.
What I would like to know are some best practices for installing and sealing the new plates up through the cabin top and the best material to use. I haven't been back up on deck to do more cleaning of the holes for the chainplates and do any isolation, but will do so on a good weather day. Torque values on the bolts, or just run them good and snug? What else do I want to know before putting this part of the puzzle back together?
Re: Chainplate Re-installation
[Re: Coastie]
#17697
02/18/18 08:22 PM
02/18/18 08:22 PM
Coastie
Scappoose, OR
Bill, What is your recommendation for the sealer material in the cabin top around the chainplate? Whatever had been used before had worked, but it had become brittle which seems like a bad thing.
47
guests, and 14
