Freshwater Bottom Paint
#17740
03/04/18 01:16 PM
03/04/18 01:16 PM
Posts: 218 Scappoose, OR
Coastie
Scappoose, OR
Like Russ I am eating the elephant one bite at a time using some steak sauce occasionally. I have a small amount of glasswork to complete as it gets warmer, then fairing and barrier coating, but then it is on to something more normal like bottom painting.
Majic Carpet will be in freshwater 95% of the time with some short stints into saltwater. What bottom paints would work well for this situation?
Re: Freshwater Bottom Paint
[Re: Coastie]
#17742
03/05/18 01:39 PM
03/05/18 01:39 PM
Coastie
Scappoose, OR
I can buy the VC 17m at a discount, so will likely go that route. Then I get to decide just how much barrier coating is really required over epoxy lamination. It seems like 4 coats of these primers is overkill over an epoxy lamination, but I don't ever want to have to deal with what I have done over the last year.
51
guests, and 0
