Enterprise is a very well accomplished 1979 J30 hull #79. In 2012 the boat was refit with the following components / work;
Mast and boom stripped, awlgripped, re-rigged, tuned, Masthead VHF antennae, LED tricolor with strobe, thru-bar spreader upgrade, lines replaced. Steaming and deck light. LED navigation lights on mast. Harken BattCar mainsail car system, Harken Mark 2 jib furling system. Harken windward sheeting 4:1 traveler system. BoomKicker vang. 3:1 spectra adjustable backstay. Quantum Sails Fusion M mylar & carbon performance cruising sails (excellent condition). Custom Quantum storm jib w/ Harken furler (Detachable, New condition). Quantum asymmetric spinnaker with deployable bowsprit (New condition)
All deck hardware stripped, reinstalled. All wet core removed. Not one wet spot on the boat. Gelcoat awlgripped, nonskid Kiwi-Gripped. New Lewmar hatches throughout. 3 deck hatches and 6 opening portholes. Solar vent, Custom stainless steel split bow pulpit, grab trails, and stern rail. Custom Dodger made to fit the J30, supporting a 100 Watt flexible solar panel. Lewmar #35 self-tailing winches for jib handling, Lewmar #25 self-tailing winches for halyard handling. Lewmar clutches. Offshore life-sling. Access hatch over transmission (2018), Telescoping Harken Battle-Stick. Bottom stripped to gelcoat, faired, VC-offshore bottom (white). Massive 45lb original Danforth anchor.
Completely re-wired during the refit. 115V shore power system w/ 3 GFIC outlets in the galley. 2 Large house batteries (2016) 30 amp shorepower cord. Marine battery charger. Most lighting is LED w/ red function. New 12v control panel, weather station, Bluetooth stereo w/ 4 marine speakers. Hand-held VHF. 3G enabled tablet used as a chart plotter. Sunforce solar charger, Go Power 300 Watt inverter bulkhead mounted. Raymarine ST 2000 autopilot performs well.
Yanmar 2QM-15 maintained to aircraft standards. New shaft, Folding prop, Dripless seal (2016) All belts, filters, Water pump (2018). Extensive tool inventory and Yanmar spares kit. Consumes and leaks no oil.
Simple, no fuss interior. Sleeps 6, 6ft headroom, ample storage, large icebox. 30 gallons freshwater, 14 gallons diesel, 10 gallons auxiliary diesel. Interior wood refinished (2018). Non-pressurized alcohol stove. Magma propane grill. Self contained marine head (2016) (No smells!)
2001 10 Foot Zodiac and 2001 3 HP Yamaha is included. Excellent condition. It is able to be rolled up and stowed below.
I have personally sailed this boat from Rhode Island to the Bahamas without 1 problem. Delivery to you on East Coast of USA is included. The boat is registered in Newport. Survey available at request.
Asking price reduced is $20,000. Please contact Paul at pireland55@aol.com
http://www.sailboatlistings.com/view/71005
