Hi All
Just looking for a bit of info. I have a constant puddle at the bottom of my mast and last night i found where it was coming from. The holes that the electronic wire is coming through have are full of sealant so no water can escape so basically my mast fills with water. Should it be like this or should there be a drain hole at the bottom of the mast???
I don'tr understand why you would want to have water in your mast any idea's?
Thanks
