Re: Changing out wire main and Jib halyard
[Re: Pabs]
#17823
04/27/18 08:31 PM
04/27/18 08:31 PM
Posts: 9 Melbourne Beach, FL
fcd
Melbourne Beach, FL
The masthead is the same as a J/24, except there are two. Good luck changing the inner one with the mast up, I had trouble with it with the mast down. It has to come up from the bottom, and the masthead is pretty small. I thought I bought mine from http://www.apsltd.com/J24-Sparcraft-Welded-in-Masthead-Parts.html but the sheave I got was aluminum. For the jib halyard box, I was able to move around unused sheaves, so I only had to replace a couple. On the older box in order to replace those you have to pull the box out and find someone who can rivet new ones in.
[Re: Rhapsody #348]
#17854
05/21/18 07:12 PM
05/21/18 07:12 PM
Posts: 58 BC
Pabs
BC
The rope should pass through no problem. The sheaves should be changed because the grove for the wire will abraid the rope cover. I checked the sheave it seams good still no groove where the wire is. Should I be able to pull the wire spliced part of the rope through the sheave? maybe I am not pulling hard enough?
34
guests, and 1
spider. |
