January
nye87, Killian, newbie_owner, Fred Schroth, Salish Sea Benji
860 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
744,221 Dacron Main
Topics3,618
Posts17,863
Members860
Most Online104
Feb 12th, 2014
Changing out wire main and Jib halyard #17807
04/22/18 01:29 PM
04/22/18 01:29 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Whats the best way to do this?
I don't think the connection between the wire and the rope will go through the mast sheave so I guess the only option would be is to cut the end with the shackle on and pull through the mast exit point? Or have you guys been able to pull it through the sheave? I haven't been up the mast but my rigger who did the inspection told me I can use the existing ones.
Thanks
Re: Changing out wire main and Jib halyard [Re: Pabs] #17808
04/22/18 05:05 PM
04/22/18 05:05 PM
The rope should pass through no problem. The sheaves should be changed because the grove for the wire will abraid the rope cover.
Re: Changing out wire main and Jib halyard [Re: Rhapsody #348] #17809
04/23/18 02:49 PM
04/23/18 02:49 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Where can I find the sizes of the Sheaves I may as well replace them all.
Re: Changing out wire main and Jib halyard [Re: Pabs] #17823
04/27/18 07:31 PM
04/27/18 07:31 PM
Melbourne Beach, FL
fcd Offline
fcd  Offline
Melbourne Beach, FL
The masthead is the same as a J/24, except there are two. Good luck changing the inner one with the mast up, I had trouble with it with the mast down. It has to come up from the bottom, and the masthead is pretty small. I thought I bought mine from http://www.apsltd.com/J24-Sparcraft-Welded-in-Masthead-Parts.html but the sheave I got was aluminum. For the jib halyard box, I was able to move around unused sheaves, so I only had to replace a couple. On the older box in order to replace those you have to pull the box out and find someone who can rivet new ones in.
Re: Changing out wire main and Jib halyard [Re: Rhapsody #348] #17854
05/21/18 06:12 PM
05/21/18 06:12 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
I checked the sheave it seams good still no groove where the wire is. Should I be able to pull the wire spliced part of the rope through the sheave? maybe I am not pulling hard enough?
Re: Changing out wire main and Jib halyard [Re: Pabs] #17855
05/22/18 10:31 AM
05/22/18 10:31 AM
Highland Park, NJ
Steve Buzbee Offline
Highland Park, NJ
I switched to rope from wire years ago without changing sheaves and have had no issues with chafe. And you should be able to pull the wire/rope splice through without too much trouble.
Blue Meanie J/30 #485
0 registered members (), 16 guests, and 0 spiders.
First cruise
HURRICANE HARVEY WIND SEED
1983 J/30 Hull #427 Taku
by nathankt79. 01/23/19 09:18 AM
2019 NA's
by David Erwin. 01/21/19 11:02 AM
ORRez
by nathankt79. 01/17/19 10:20 AM
Spinnaker Pole End
by Rob Van Name. 01/15/19 04:41 PM
Prop selection help
by nathankt79. 01/15/19 02:43 PM
For Sale - Screamin' O #35
by jheinzle. 01/05/19 04:30 PM
J/30 Class is now a West Marine affiliate
by Bickertp45. 01/03/19 02:56 AM
J 30 for sale
by nathankt79. 12/26/18 02:06 PM
Stress Cracks from Accident
by nathankt79. 12/18/18 04:36 PM
