January
nye87, Killian, newbie_owner, Fred Schroth, Salish Sea Benji
860 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
744,221 Dacron Main
Topics3,618
Posts17,863
Members860
Most Online104
Feb 12th, 2014
Dripless Stuffing Box Leaking #17839
05/03/18 04:41 PM
05/03/18 04:41 PM
Annapolis
JPM Offline OP
JPM  Offline OP
Annapolis
The saga with Blitz continues:
I had the boat out of the water over the winter. New bottom, rebalance prop, etc. Had her put in yesterday thinking I would be good to go for NOODs this weekend here in Annapolis. No joy...
Dropped the boat into gear and the dripless stuffing box began spewing water. I "burped" it before starting the engine to ensure there was a wet seal established before turning the prop. No issues in reverse but as soon as she goes in forward I get water...and not a small amount of it.
It seems like the carbon ring slips lower on the stainless rotor thereby allowing the leak. I can re-center the ring while the shaft is turning and the leaking stops.
I've read that I can move the steel rotor aft to get more compression on the bellows but I wanted to see if anyone else had experienced this issue.
My alternative option is to replace the entire system.
Thanks....
Re: Dripless Stuffing Box Leaking [Re: JPM] #17841
05/04/18 03:54 PM
05/04/18 03:54 PM
Move the ring. Also check to make sure you don't have a bad engine mount where the rubber has separated causing more engine movement. Also check that the shaft is locked in tight to the coupling and not sliding.
0 registered members (), 16 guests, and 0 spiders.
First cruise
HURRICANE HARVEY WIND SEED
1983 J/30 Hull #427 Taku
by nathankt79. 01/23/19 09:18 AM
2019 NA's
by David Erwin. 01/21/19 11:02 AM
ORRez
by nathankt79. 01/17/19 10:20 AM
Spinnaker Pole End
by Rob Van Name. 01/15/19 04:41 PM
Prop selection help
by nathankt79. 01/15/19 02:43 PM
For Sale - Screamin' O #35
by jheinzle. 01/05/19 04:30 PM
J/30 Class is now a West Marine affiliate
by Bickertp45. 01/03/19 02:56 AM
J 30 for sale
by nathankt79. 12/26/18 02:06 PM
Stress Cracks from Accident
by nathankt79. 12/18/18 04:36 PM
