977,746 Dacron Main
163,145 Ananda's Refit
Where To Break Hull Paint #17874
06/29/18 03:02 PM
06/29/18 03:02 PM
Scappoose, OR
Coastie Offline OP
Coastie  Offline OP
Scappoose, OR
I'm getting ready for the next big adventure in the rebuilding of MaJic Carpet, hull painting. The bottom of the boat is as good as it is going to get at this point in time so I am now starting to prep for the hull paint. I am curious where others have broken the color from the hull to the deck. I am sure that it needs to wrap up onto the deck, but should the break be at the bottom edge of the toe rail, or maybe just short of it, say 1/4" away. That would make taping off everything a bit easier.
I had been concerned that cleaning up the toe rails and refinishing them would be a pain, but so far so good. The teak is showing its worth here, the old finish scrapes pretty easily and then even the black stains sand away really well. This is much more fun than sanding the bottom of the boat for the umpteenth jillion time.
20180629_113033_resize.jpg [66.58 KBytes] - (268 downloads)
Re: Where To Break Hull Paint [Re: Coastie] #17879
07/06/18 11:09 PM
07/06/18 11:09 PM
Scappoose, OR
Coastie Offline OP
Coastie  Offline OP
Scappoose, OR
The plan is to break the paint 1/2" from the toe rail. This also allows me to postpone work on the nasty hull/deck joint for another day.
I did notice that my toe rail is actually a little loose in a couple of places so will grow some inches on the arms to reach in and re-tighten the fasteners.
0 registered members (), 36 guests, and 1 spider.
