hatch choice help
#17913
07/30/18 02:20 PM
07/30/18 02:20 PM
Posts: 76 Burton, Michigan
nathankt79
Burton, Michigan
Good afternoon. I have recently purchased a 1984 J30. The hatches are what I believe to be OEM. They're black plastic and are pretty well sun rotted to the point that they're brittle and some small leaks have started. I would like to find a more robust replacement. However, just like everything I'm learning (new to sailing), there's a lot more to it than I originally thought.
First, I would like the hatch to be watertight while not snagging sails or other rigging...Wait, first, I would like to find one that will fit what I believe to be OEM cutouts. The forward hatch being something like 19-7/8" square. Second, I would like them robust and long-lived. Third, I would like them to compliment the looks of the boat. She is white with light pearl grey nonskid. The toe rails and mast are black and all bright work has been replaced by stainless. Stainless would be ideal for looks, except it seems that most I have seen in stainless don't have reinforced windows. Next choice would be cast aluminum with a clear or black anodize. I'm not sure what material, construction, brand, or profile I should go for. I've been looking at Lewmar and Bomar.
Can anyone please chime in here?
Nate
Re: hatch choice help
[Re: nathankt79]
#17914
07/30/18 02:29 PM
07/30/18 02:29 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
lewmar Ocean 60, no flange for the forward hatch
Lewmar Ocean 10, no flange for the other two
You can look at the pic of Zephyr on the front page.
[Re: nathankt79]
#17920
07/31/18 12:01 PM
07/31/18 12:01 PM
D. Bartley
Chicago, Il. USA
That's actually not my boat, but I've done the same thing.
I don't know that the flange for the Lewmar hatches fit the opening properly. Flangeless works fine.
You can mount the small hatches any way you wish. If I remember both of my originals were facing aft, so I did the same.
[Re: nathankt79]
#17930
07/31/18 07:21 PM
07/31/18 07:21 PM
D. Bartley
Chicago, Il. USA
Forward facing hatch could encourage more air circulation, but catch more water if a wave came over.
No idea about a vent fan. Sorry
44
guests, and 1
spider. |
