mattjenPDX71, loic, Cousineddy, Captain Rick, Boat Boxer
915 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
841,343 Dacron Main
127,092 Ananda's Refit
Topics3,730
Posts18,281
Members914
Most Online223
Dec 17th, 2019
hatch choice help #17913
07/30/18 02:20 PM
07/30/18 02:20 PM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Good afternoon. I have recently purchased a 1984 J30. The hatches are what I believe to be OEM. They're black plastic and are pretty well sun rotted to the point that they're brittle and some small leaks have started. I would like to find a more robust replacement. However, just like everything I'm learning (new to sailing), there's a lot more to it than I originally thought.
First, I would like the hatch to be watertight while not snagging sails or other rigging...Wait, first, I would like to find one that will fit what I believe to be OEM cutouts. The forward hatch being something like 19-7/8" square. Second, I would like them robust and long-lived. Third, I would like them to compliment the looks of the boat. She is white with light pearl grey nonskid. The toe rails and mast are black and all bright work has been replaced by stainless. Stainless would be ideal for looks, except it seems that most I have seen in stainless don't have reinforced windows. Next choice would be cast aluminum with a clear or black anodize. I'm not sure what material, construction, brand, or profile I should go for. I've been looking at Lewmar and Bomar.
Can anyone please chime in here?
Nate
Re: hatch choice help [Re: nathankt79] #17914
07/30/18 02:29 PM
07/30/18 02:29 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
lewmar Ocean 60, no flange for the forward hatch
Lewmar Ocean 10, no flange for the other two
You can look at the pic of Zephyr on the front page.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: hatch choice help [Re: D. Bartley] #17915
07/30/18 02:43 PM
07/30/18 02:43 PM
Burton, Michigan
N
N
Burton, Michigan
Dennis,
Thanks for getting back to me so quickly. Why no flange? The ones I currently have on there (rotting black plastic), have a flange...This is assuming that the plastic that extends from the sealing surface (screwed to deck) through the cutout opening is the flange. I'm not arguing...just trying to understand.
Nate
Re: hatch choice help [Re: D. Bartley] #17916
07/30/18 02:46 PM
07/30/18 02:46 PM
Burton, Michigan
N
N
Burton, Michigan
Dennis,
I also noticed that you replaced the two smaller ones with the hatches facing rearward. I couldn't tell if you did that for the forward hatch. What was your reasoning there?
Nate
Re: hatch choice help [Re: nathankt79] #17920
07/31/18 12:01 PM
07/31/18 12:01 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
That's actually not my boat, but I've done the same thing.
I don't know that the flange for the Lewmar hatches fit the opening properly. Flangeless works fine.
You can mount the small hatches any way you wish. If I remember both of my originals were facing aft, so I did the same.
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: hatch choice help [Re: D. Bartley] #17924
07/31/18 12:32 PM
07/31/18 12:32 PM
Burton, Michigan
N
N
Burton, Michigan
Thanks again. Aside from installing how they were, are there any advantages to forward or rear facing? Also, do you recommend any particular day/night vent fan?
Re: hatch choice help [Re: nathankt79] #17930
07/31/18 07:21 PM
07/31/18 07:21 PM
Chicago, Il. USA
D. Bartley Offline
D. Bartley  Offline
Chicago, Il. USA
Forward facing hatch could encourage more air circulation, but catch more water if a wave came over.
No idea about a vent fan. Sorry
Dennis Bartley
Planxty, s/n 23994
hull 205
Re: hatch choice help [Re: nathankt79] #17931
08/01/18 04:28 AM
08/01/18 04:28 AM
Scotland
J
Jim Hoey Offline
Jim Hoey  Offline
J
Scotland
You need the flangeless hatch as the one with the flange is too big.
Re: hatch choice help [Re: Jim Hoey] #17932
08/01/18 09:08 AM
08/01/18 09:08 AM
Burton, Michigan
N
N
Burton, Michigan
Thank you. Without taking everything apart, it's difficult to really get a good measurement. I did verify with the previous owner that everything is OEM. He rebuilt a lot of things, but the hatches have remained "as is". I'm glad I didn't learn the hard way.
Re: hatch choice help [Re: nathankt79] #17943
08/04/18 02:35 PM
08/04/18 02:35 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
Majic carpet now has the Lewmars listed above. These are very robust hatches and I suspect they will survive a very long time. The installation required filling a lot of old holes and then drilling and isolating the new ones. all of the new bolts are full length thru bolts with acorn nuts This is a key detail to keeping the flange sealed to the hull. No short cuts here. the new hatches kept rain and snow out all winter here in Oregon so I think they are good to go now. These also work great and the large hatch can be left in multiple positions and it stays in place the same is true for the smaller hatches. This was not an inexpensive upgrade, but it is a worthwhile one if you like to keep the H2O on the outside of the boat and not in the cabin The old hatches on my boat were so bad it was like being under a waterfall when it rained.
20170916_150728_resize.jpg [86.46 KBytes] - (195 downloads)
20170916_150731_resize.jpg [109.98 KBytes] - (214 downloads)
2 registered members (J/30, Rhapsody #348), 57 guests, and 1 spider.
First cruise
Shroud Tension Tuning
by usa1136. 08/02/20 11:01 AM
#484 "Conundrum" for sale
by nathankt79. 07/29/20 07:31 PM
by Koesh. 07/27/20 02:22 PM
Simple cruising douse
by Rajesh Verma. 07/20/20 07:05 AM
One of the best things about sailing offshore...
by Rajesh Verma. 07/20/20 07:04 AM
WTB: Lower Shrouds (Replacement)
by Rhapsody #348. 07/19/20 12:17 PM
3 way/Y-Valve handle
by Rhapsody #348. 07/10/20 03:53 PM
New North Main - too long?
by Georges. 07/01/20 02:27 PM
How to re-bed hand rails?
by Russ Atkinson. 07/01/20 10:36 AM
Where Can a Guy Get a Sink Around Here!?
by Koesh. 06/21/20 12:52 AM
