977,684 Dacron Main
163,120 Ananda's Refit
Re: hatch choice help [Re: Coastie] #17945
08/06/18 08:48 AM
08/06/18 08:48 AM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Thank you Dave! Were the hatches you ordered flanged or flat? Were they the same size 10 and 60 ocean hatches that I'm looking at purchasing? I just want to be sure. As you mentioned, this won't be terribly cheap. However, its cheaper than water getting in.
Nate
Re: hatch choice help [Re: nathankt79] #17947
08/06/18 12:25 PM
08/06/18 12:25 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
These hatches were the flat arrangement. I think hte trick to them is to do the through bolting which is a lot of new stainless bolts. I alo used the semi permanent 5200 under the frames because I don't think there will be a next time on these hatches and for sure I don't ever want to mess with them again.
Re: hatch choice help [Re: Coastie] #17951
08/06/18 01:10 PM
08/06/18 01:10 PM
Burton, Michigan
N
N
Burton, Michigan
Thank you for the input!
0 registered members (), 48 guests, and 0 spiders.
