March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,432 Dacron Main
162,696 Ananda's Refit
Re: hatch choice help [Re: Coastie] #17945
08/06/18 08:48 AM
08/06/18 08:48 AM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Thank you Dave! Were the hatches you ordered flanged or flat? Were they the same size 10 and 60 ocean hatches that I'm looking at purchasing? I just want to be sure. As you mentioned, this won't be terribly cheap. However, its cheaper than water getting in.
Nate
Re: hatch choice help [Re: nathankt79] #17947
08/06/18 12:25 PM
08/06/18 12:25 PM
Scappoose, OR
Coastie Offline
Coastie  Offline
Scappoose, OR
These hatches were the flat arrangement. I think hte trick to them is to do the through bolting which is a lot of new stainless bolts. I alo used the semi permanent 5200 under the frames because I don't think there will be a next time on these hatches and for sure I don't ever want to mess with them again.
Re: hatch choice help [Re: Coastie] #17951
08/06/18 01:10 PM
08/06/18 01:10 PM
Burton, Michigan
N
N
Burton, Michigan
Thank you for the input!
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
