978,305 Dacron Main
163,315 Ananda's Refit
boom screw issue #17953
08/06/18 03:22 PM
08/06/18 03:22 PM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Has anyone else had an issue with the three boom screws holding the extrusion to the J-neck coming lose? I've been told that "everything" has been tried and I just need to check tightness periodically. I believe there must be a solution someone has come up with. Currently, my fasteners are stainless, phillips head screws.
Any thoughts?
Re: boom screw issue [Re: nathankt79] #17955
08/06/18 04:38 PM
08/06/18 04:38 PM
Scotland
J
Jim Hoey Offline
Jim Hoey  Offline
J
Scotland
Try loctite threadlock.
Re: boom screw issue [Re: nathankt79] #17956
08/06/18 06:15 PM
08/06/18 06:15 PM
MD
U
usa1136 Offline
usa1136  Offline
U
MD
Drill, tap, bolt with locktite
Re: boom screw issue [Re: nathankt79] #17957
08/06/18 07:47 PM
08/06/18 07:47 PM
Overdrill fitting and screw in stainless helicolis (threaded inserts).
Re: boom screw issue [Re: nathankt79] #17959
08/06/18 10:01 PM
08/06/18 10:01 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
Or... two (one on each side) can be thru bolted and held with a nylock nut
Re: boom screw issue [Re: Russ Atkinson] #17962
08/07/18 08:10 AM
08/07/18 08:10 AM
Burton, Michigan
N
N
Burton, Michigan
No kidding? I haven't looked that close at the extrusion to see about access on the back side. Thanks!
