J/Fest New England
Aug 10-11, 2019
Sail Newport
Registration
February
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28
KarenR, Doug E., aquagirl, KnotSpeeding, Wind Dancer 206
865 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
748,821 Dacron Main
101,447 Ananda's Refit
Topics3,625
Posts17,891
Members865
Most Online104
Feb 12th, 2014
packing gland #18002
10/08/18 11:23 AM
10/08/18 11:23 AM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Can anyone tell me where to look for quality packing gland assemblies?
Nate
Re: packing gland [Re: nathankt79] #18013
10/12/18 06:35 PM
10/12/18 06:35 PM
Belmont, MA
G
Georges Offline
Georges  Offline
G
Belmont, MA
https://www.defender.com/product3.jsp?path=-1|311|2349117|2349129&id=685485
My J/30 is a 1984 model with a 1" shaft - so 1/4" is the size for me.
I do not know if that would be the same with earlier modesl 3/4" shaft.
I love the GTU, have been using it for years now: it does not overheat even if you get a bit paranoid on the tightening, it does not bite (too much) into the shaft either.
-- Georges
Re: packing gland [Re: Georges] #18021
10/15/18 09:05 AM
10/15/18 09:05 AM
Burton, Michigan
N
N
Burton, Michigan
Thank you for the link! That packing does look like the ticket. I don't really know how to tell when the packing is shot. I was able to adjust it this weekend where it didn't leak when engine was off or in neutral...but when the shaft is spinning in forward or reverse, I can see a wet ring just forward of the nut. This was repeated a couple of times while tied up in the slip and I dried everything up in between tests to make sure I wasn't just seeing residual water. However, I never did see a repeatable "drip per minute". The adjustment was done by hand and only amounted to maybe a 16th of a turn tighter. I tightened the jam nut while holding the adjusting nut with a good pair of large channel locks. My thought is that the wet ring is telling me water is lubing the packing against the shaft.
Unless anyone thinks differently, I think I got it adjusted about as good as can be. Please chime in if you don't though. I am pretty new to this.
Nate
0 registered members (), 44 guests, and 0 spiders.
First cruise
HURRICANE HARVEY WIND SEED
by nathankt79. 02/21/19 02:13 PM
#3 Measurements
by Rhapsody #348. 02/21/19 11:05 AM
Rudder replacement
by forbes. 02/21/19 10:17 AM
Drifter/Wind seeker used or advice on new
by Pabs. 02/18/19 11:25 PM
J29 main on a J30
by Pabs. 02/18/19 11:23 PM
Set Your Races & Schedule Your Crew
by Rhapsody #348. 02/17/19 10:25 PM
1979 J/30 # 82 Presto! in Seabrook, TX
by Stuart Smith. 02/02/19 04:21 PM
Looking to buy a J30 sailboat
by ivanjrod. 01/29/19 09:41 PM
Small hatches - core
by lumpy. 01/28/19 04:13 PM
