4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30
Bill492, Syzygy, gseorget, Michael Foster, Maggie McN
1008 Registered Users
964,854 Dacron Main
159,395 Ananda's Refit
Topics3,964
Posts19,013
Members1,009
Most Online223
Dec 17th, 2019
Electrics failed #18025
10/21/18 11:00 PM
10/21/18 11:00 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
My Electrics have suddenly failed and I can't work out why. I gad an issue with my nav lights and i thought i had found the issue. When I went to turn them on everything switched off my panel appears to not be getting any power and I can't work out why as I have power going to my engine and peering the engine panel. Thoughts????
Re: Electrics failed [Re: Pabs] #18026
10/22/18 06:42 AM
10/22/18 06:42 AM
There is a fuse holder buried in the harness near the battery switch on the output of the selector switch. It probably has corroded internally and needs to be replaced. Many boats have exhibited this problem.
Re: Electrics failed [Re: Pabs] #18029
10/22/18 09:46 PM
10/22/18 09:46 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Found it!! thanks so much also found that my navigation wire is toast. Do you know what cable I should use to replace it? 14 or 12 gauge?
Re: Electrics failed [Re: Pabs] #18031
10/23/18 01:39 PM
10/23/18 01:39 PM
How much current does it take and what is the length of the run?
Re: Electrics failed [Re: Pabs] #18032
10/23/18 02:50 PM
10/23/18 02:50 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Its a 30' run in total and the lights are LED unfortunately I can't find what there current usage is.
Re: Electrics failed [Re: Pabs] #18036
10/24/18 08:26 AM
10/24/18 08:26 AM
Burton, Michigan
N
nathankt79 Offline
nathankt79  Offline
N
Burton, Michigan
I'm not an electrician, but I would go with the #12 wire...runs cooler, has less current drop over length, and can take a higher amp draw without resulting in excess heat or load on the unit. However, when in doubt, replace it with what was there if it worked that way for a long time.
Re: Electrics failed [Re: Pabs] #18037
10/25/18 05:54 AM
10/25/18 05:54 AM
UK
Miko78 Offline
Miko78  Offline
UK
Good point the best way to solve the situation is to replace it with what was there if it worked that way for a long time.
Re: Electrics failed [Re: Pabs] #18040
10/25/18 07:05 AM
10/25/18 07:05 AM
If it is just LEDs you are more than adequate with 14 ga wire. Use marine grade tinned wire and run both the positive and negative leads.
Re: Electrics failed [Re: Pabs] #18053
11/03/18 07:35 PM
11/03/18 07:35 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
I had this fuse holder fail on Nordic Star also. Until it failed I never knew it was there.
Re: Electrics failed [Re: Pabs] #19197
05/11/23 09:22 PM
05/11/23 09:22 PM
Cleveland Hts., OH, USA
Blue J 503 Offline
Blue J 503  Offline
I'm not getting power to my engine panel (type B). Battery is reading 12V, but at key switch (off), I'm only getting 0.16V, and zero with the switch on. No buzzer or warning lights. Could this be due to a bad fuse holder as described in prior posts? There appears to be power to my interior switch panel.
0 registered members (), 33 guests, and 0 spiders.
First cruise
Need a J30 trailer
by Scot Benton. 09/22/23 12:48 PM
Newbie Electrical Questions
by Bob Rutsch. 09/11/23 02:09 PM
by Eggemoggin. 09/10/23 03:34 PM
Cockpit roles? Tiny cockpit!
by Patrick Stinson. 08/27/23 12:29 AM
Cut back V-Berth bulkhead?
by Patrick Stinson. 08/23/23 12:00 PM
by Patrick Stinson. 08/11/23 02:31 PM
Stripped Jib Halyard
by Bob Rutsch. 08/08/23 11:11 AM
Dockline fairleads
by Patrick Stinson. 07/31/23 03:57 AM
Wanted Used Main and #1 Genoa in Montreal or North East
by John McGuinness. 07/27/23 09:49 AM
