Re: Electrics failed
[Re: Pabs]
#18040
10/25/18 07:05 AM
10/25/18 07:05 AM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Its a 30' run in total and the lights are LED unfortunately I can't find what there current usage is. If it is just LEDs you are more than adequate with 14 ga wire. Use marine grade tinned wire and run both the positive and negative leads.
36
guests, and 1
spider. |
