Yanmar 2QM15 1970 - Gages
#18033
10/23/18 03:13 PM
10/23/18 03:13 PM
Posts: 868 New Orleans, LA, USA
OK my 1979 gages in hull #87 have finally stopped working. I have been reading about A Panel vs B panel. My panel doesn't look like either. You have to lift up the starboard side lazarett to insert the key to start the engine. I suspect my panel is an early A panel design. Anyone have a recommendation to source replacement instruments?
Yanmar Part Number
124070-91100 Tachometer
____________ Oil Pressure Gage?
____________ Voltage Gage?
Looking for ideas...
eBay Find!
Re: Yanmar 2QM15 1970 - Gages
[Re: David Erwin]
#18043
10/26/18 03:11 AM
10/26/18 03:11 AM
Posts: 4 UK
Miko78
UK
I also had a bad thing happened to my boat. Luckily, my best friend offered to help me by supervising repair works onboard on a daily basis while I was away for my business. The whole story can be read here https://princess55fly.blogspot.com/p/home.html. Because of that situation, I couldn't use my boat for a long time. Really big trouble.
48
guests, and 13
