J/Fest New England
Aug 10-11, 2019
Sail Newport
Registration
March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
amtdys, Joao Brito CHILE, KarenR, Doug E., aquagirl
867 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
753,426 Dacron Main
102,830 Ananda's Refit
Topics3,632
Posts17,919
Members867
Most Online124
Mar 5th, 2019
Yanmar 2QM15 1970 - Gages #18033
10/23/18 03:13 PM
10/23/18 03:13 PM
New Orleans, LA, USA
David Erwin Offline OP
J/30 Class Co-President
OK my 1979 gages in hull #87 have finally stopped working. I have been reading about A Panel vs B panel. My panel doesn't look like either. You have to lift up the starboard side lazarett to insert the key to start the engine. I suspect my panel is an early A panel design. Anyone have a recommendation to source replacement instruments?
Yanmar Part Number
124070-91100 Tachometer
____________ Oil Pressure Gage?
____________ Voltage Gage?
Looking for ideas...
eBay Find!
Re: Yanmar 2QM15 1970 - Gages [Re: David Erwin] #18035
10/23/18 04:30 PM
10/23/18 04:30 PM
Burton, Michigan
N
nathankt79 Offline
nathankt79  Offline
N
Burton, Michigan
I just had the same thing happen...tachometer quit while taking her to her winter sleeping spot. I've got the panel where the key and panel is mounted pretty well centered on the inside of the transom. If anyone has a source for these, please let me know as well.
Nate
Re: Yanmar 2QM15 1970 - Gages [Re: David Erwin] #18041
10/25/18 07:19 AM
10/25/18 07:19 AM
If everything stops working I suspect it is the return line connection common to all the gauges. Take a meter/continuity tester and ring out all the lines from the panel back to the engine. I suspect you'll find a broken wire or bad connection.
For the tachometer, there is a sensor mounted on the bell housing by the flywheel that generates pulses for the tachometer. Most likely there is a loose connection there. Pull the spade type contact connector off, clean the terminals and if needed gently squeeze the female spade terminal to close the contacts so they seat better.
Re: Yanmar 2QM15 1970 - Gages [Re: David Erwin] #18043
10/26/18 03:11 AM
10/26/18 03:11 AM
UK
Miko78 Offline
Miko78  Offline
UK
I also had a bad thing happened to my boat. Luckily, my best friend offered to help me by supervising repair works onboard on a daily basis while I was away for my business. The whole story can be read here https://princess55fly.blogspot.com/p/home.html. Because of that situation, I couldn't use my boat for a long time. Really big trouble.
0 registered members (), 48 guests, and 2 spiders.
First cruise
HURRICANE HARVEY WIND SEED
Weight and waterline
by nathankt79. 03/21/19 08:30 AM
best replacement batteries?
by Chris623. 03/14/19 08:24 PM
Looking for SPIN Pole End
by megreene52. 03/12/19 03:26 PM
1983 J/30 Hull #427 Taku
by Taku. 03/06/19 12:11 PM
Engine starting question
by last fling IV. 03/05/19 03:52 PM
Looking for NA Photo Blitz
by David Erwin. 03/05/19 10:07 AM
Lines back to the cockpit
by Pabs. 02/27/19 05:06 PM
#3 Measurements
by usa1136. 02/26/19 12:14 AM
Set Your Races & Schedule Your Crew
by Rhapsody #348. 02/25/19 03:09 PM
Shroud Grommets
by Rhapsody #348. 02/25/19 02:52 PM
